- To: Coq-Club <coq-club AT inria.fr>
- Subject: [Coq-Club] mllib vs mlpack
- Date: Thu, 16 Nov 2017 15:21:53 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM02-SN1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:vqE6ZhE2iCBbH00aoY+SRZ1GYnF86YWxBRYc798ds5kLTJ76ocmwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVTz74LE9eIvn/UtrZiN3y3OSv8bXSZR9JjXyze+UhAg+xqFDyu88QjJdiYpw2x1OdoXZOd/5RyEtoIk6Wlhf4oMy3+cgwoGxrp/s9+psYAu3BdKMiQOkAAQ==
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Coq 8.7 supports two packaging mechanisms for plugins, "mllib" and "mlpack". Towards the end of my .ml4 file, I have the following declarations:
TACTIC EXTEND AR2
| ["arewrite"] -> [Stuff.arewrite]
END
(* PrintAST command
The depth specifies the depth at which to unroll nested type definitions *)
VERNAC COMMAND EXTEND AR
| [ "printAST" constr(def) ] -> [ Stuff.print_ast 0 def ]
| [ "printExp" constr(def) ] -> [ Stuff.print_exp 0 def ]
| [ "printAST" constr(def) "with" "depth" integer(depth)] -> [ Stuff.print_ast depth def ]
END
After doing some experimentation, I found that with mllib everything works. However, when I package everything into an mlpack library, the "arewrite" tactic is not recognized. However, the "printAST" and "printExp" commands are recognized. Do TACTIC declarations
need to be done differently for an mlpack?
- Ken
- [Coq-Club] mllib vs mlpack, Kenneth Roe, 11/16/2017
