- To: Kenneth Roe <kendroe AT hotmail.com>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Walking the Coq environment for an ml-plugin
- Date: Sat, 18 Nov 2017 15:08:42 +0100
Hi,
> From the ml code inside the "arewrite" tactic, I need to traverse the
> environment and retrieve the "fact" and "ac_plus" declarations. It would
> also
> be useful to traverse the declarations in any modules that are imported.
> How
> can I do this?
I suspect that your question was finally more about looking up a
declaration in the environment and that Talia answered. If it is
really about traversing the environment, as e.g. "Search" or "Print
All" would do, I wrote a little general-purpose answer on the wiki,
recently moved to GitHub
(https://github.com/coq/coq/wiki/Development-questions).
Best,
Hugo Herbelin
On Fri, Nov 17, 2017 at 02:21:23PM +0000, Kenneth Roe wrote:
> One of the requirements for my "arewrite" tactic is the ability to walk
> through
> and collect all available definitions from the environment. Consider a Coq
> source file with the following:
> Require Import AdvancedRewrite.advancedRewrite.
> Fixpoint fact (x : nat) := match x with
> 0 => 1
> S n => fact n
> end.
> Theorem ac_plus: AC plus.
> Theorem test1: fact 4 = 24.
> Proof.
> arewrite.
> Abort.
> also
> How
> can I do this?
> - Ken
- [Coq-Club] Walking the Coq environment for an ml-plugin, Kenneth Roe, 11/17/2017
- Re: [Coq-Club] Walking the Coq environment for an ml-plugin, Hugo Herbelin, 11/18/2017
