- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Missing a detail on type checking -- bad error reporting?
- Date: Mon, 27 Nov 2017 21:28:49 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua0-f169.google.com
- Ironport-phdr: 9a23:AMX2AxfawrAd4Ta9L4e4+BjslGMj4u6mDksu8pMizoh2WeGdxc2/Yh7h7PlgxGXEQZ/co6odzbGJ4+a9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpW1aJhKqPg1sY+/xB4T6jsKt1un09YeATR9PgW+YaK9uLBS7sE3qsdsbiJYqfqM41gfAp1NNcvhKzGYuIkicyUWvrvys9YJupnwD88kq8NRNBP33
Hi Kevin, "io.compression.codecs" <> "io_compression_codecs", as far as I can see.
On Mon, Nov 27, 2017 at 10:26 PM Kevin Sullivan <sullivan.kevinj AT gmail.com> wrote:
Dear all. First, thanks in advance for always being an incredibly helpful community.I wonder what conditions precisely lead to an error at typechecking time of the form, "The term X has type T while it is expected to have type T." Here is a concrete example from the little code-base I'm working on.The term"{|field_final := isFinal;field_value := value;field_rwt_ok := pf |}"has type"FieldmTipe_string"io.compression.codecs"io_compression_codecs_rwt"while it is expected to have type"FieldmTipe_string"io_compression_codecs"io_compression_codecs_rwt".The type, the Field type constructor, here, is parameterized by several *values* including a string value. That, I expect, is where the problem is. What am I missing about dependent type checking? (Or is there another issue I'm missing?)Here's a code isolate of just a few lines that exhibits the problem (in the last definition).Should Coq produce a better error message here?Thank you!Kevin===Require Import String.Require Export Coq.ZArith.BinInt.(*Machine types.*)Inductive MTipe := mTipe_Z | mTipe_string | mTipe_bool.Definition mType (mt: MTipe): Type :=match mt with| mTipe_Z => Z| mTipe_string => string| mTipe_bool => boolend.Inductive Field (field_mtipe: MTipe) (field_name: string) (field_rwt: (mType field_mtipe) -> Prop) := mk_field {field_final: bool; field_value: (mType field_mtipe); field_rwt_ok: field_rwt field_value}.Definition io_compression_codecs_rwt: string -> Prop := fun s => True. (* Allow any string for now *)Record hadoop_core_config := mk_hadoop_core_config {field_io_compression_codecs: Field mTipe_string "io_compression_codecs" io_compression_codecs_rwt}.Definition mk_io_compression_codecs (isFinal: bool) (value: string) (pf: io_compression_codecs_rwt value):Field mTipe_string "io_compression_codecs" io_compression_codecs_rwt :=mk_field mTipe_string "io.compression.codecs" io_compression_codecs_rwt isFinal value pf.
- [Coq-Club] Missing a detail on type checking -- bad error reporting?, Kevin Sullivan, 11/27/2017
- Re: [Coq-Club] Missing a detail on type checking -- bad error reporting?, Matthieu Sozeau, 11/27/2017
- Re: [Coq-Club] Missing a detail on type checking -- bad error reporting?, Kevin Sullivan, 11/27/2017
- Re: [Coq-Club] Missing a detail on type checking -- bad error reporting?, Ralf Jung, 11/28/2017
- Re: [Coq-Club] Missing a detail on type checking -- bad error reporting?, Pierre Courtieu, 11/28/2017
