- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] refine and shelved goals
- Date: Wed, 29 Nov 2017 22:27:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
- Ironport-phdr: 9a23:29PZ0BysMtHRaaPXCy+O+j09IxM/srCxBDY+r6Qd0uITIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2UXSJ/Sb3tWJaWkindFk9GuOgEYnLys+zyuqa+pvJYgwOiiDuT6l1KUCMqg/bu9MKyah4J6w7xwHS6i9NcuVSxGVnIVOIgw3U/MC69pN57ydKtvgr+tRbF6P+KfdrBYdEBSgrZjhmrPbgsgPOGFbX6w==
There is also the `unshelve` tactical. You can write `unshelve t`; which will execute `t` and turn all shelved goals produced by `t` into unshelved goals.
On 2017-11-29 22:22, Kevin Sullivan wrote:
Thank you. Yes, that is what I've done so far (see the proof script below).
The concern is that "This is a bit inconvenient because Unshelve is a
vernacular command, not Ltac, so it cannot be embedded in a scripts and
automated," per this old post:
http://coq-club.inria.narkive.com/PQalG3f4/how-to-solve-trivial-evars-automatically-so-that-they-don-t-get-shelved.
--Kevin
On Wed, Nov 29, 2017 at 4:09 PM, Tej Chajed
<tchajed AT mit.edu>
wrote:
I'm not entirely sure how things get shelved, but you can use the unshelve
tactical, which runs a tactic and turns any generated shelved goals into
subgoals.
On Wed, Nov 29, 2017 at 2:57 PM, Kevin Sullivan
<sullivan.kevinj AT gmail.com
wrote:
Dear Colleagues:
I hope to get a question across well enough without getting into too much
detail that someone will see the answer without much effort. In the
fragment of code below, I'm trying to instantiate a "core_config" record
with four fields, where each field in turn is built by calling a function
"mk" from a field-specific module, taking a bool, a value of some type
(string, Z, bool), and, finally, a proof of a proposition about that value.
As usual I don't want to have to write out proof objects, so I use refine.
There are five holes in the value that I'm refining, one after each of the
first four fields (for proofs that the values of the individual fields
satisfy certain constraints), and one at the end, for a proof that a
certain cross-field constraint is satisfied.
The problem is that although there are five holes, I get only three
subgoals, and once I discharge them, I'm left with two additional goals on
the shelf. I don't understand why that's happening. I'm not (explicitly)
introducing any meta-variables with "e" tactics. It's surely important
though to know that the goals that are being put on the shelf are those for
fields whose values are constrained by that final constraint (the last
hole).
What do I need to know about the conditions under which goals are put on
the shelf? My aim is to provide a proof script for instances of this record
type that runs automatically. Am I out of luck? Happy to provide more
details if any are needed.
Sorry for yet another newbie/occasional-user question.
Kevin
Definition a_core_config': core_config.
Proof.
refine (
mk_core_config
(io_compression_codecs.mk false "aCodecClassName" _)
(io_file_buffer_size.mk false 128%Z _)
(io_map_index_interval.mk false 128%Z _)
(io_fake_bool.mk false false _)
_
); try (exact I).
intro; inversion H.
Unshelve.
unfold io_file_buffer_size_desc.rType; omega.
unfold io_fake_bool_desc.rType; exact I.
Qed.
- [Coq-Club] refine and shelved goals, Kevin Sullivan, 11/29/2017
- Re: [Coq-Club] refine and shelved goals, Tej Chajed, 11/29/2017
- Re: [Coq-Club] refine and shelved goals, Kevin Sullivan, 11/29/2017
- Re: [Coq-Club] refine and shelved goals, Robbert Krebbers, 11/29/2017
- Re: [Coq-Club] refine and shelved goals, Gaëtan Gilbert, 11/29/2017
- Re: [Coq-Club] refine and shelved goals, Kevin Sullivan, 11/30/2017
