- From: Christian Doczkal <christian.doczkal AT ens-lyon.fr>
- To: coq-club AT inria.fr
- Cc: Michel Levy <michel.levy1948 AT gmail.com>
- Subject: Re: [Coq-Club] Module Classical, Ltac classical_right incorrect ?
- Date: Sat, 2 Dec 2017 14:11:13 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=christian.doczkal AT ens-lyon.fr; spf=Neutral smtp.mailfrom=christian.doczkal AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23:eqHWexDOZqpu8HMPodqWUyQJP3N1i/DPJgcQr6AfoPdwSP3ypcbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6lX71zMZGw3+OAxpPay1X9eK14Xkn9y1rpbUekBDgCe3SbJ0NhS/6wvL5ecMho43AaYrywDVo3JOM8hRznFrLFbbyx38/Mar4J9q9WJcvPkz9MdEeaj8ZOE8XLteSjo8ZTNmrPb3vAXOGFPcrkAXVX8bx18RW1DI
Hi,
Many (most?) Linux distributions are fairly slow as it comes to updating Coq.
On Linux, regardless of the concrete distribution, I suggest installing Coq
via opam. This makes it very easy to install ssreflect/mathcomp, many user
contributions as well as multiple versions of Coq.
Best,
Christian
On 12/01/2017 09:52 PM, Michel Levy wrote:
> Thank you Gaëtan, I am still running Coq 8.4 an old version, but the last
> version of my system Ubuntu 16.04LTS.
> Le 01/12/2017 à 21:42, Gaëtan Gilbert a écrit :
>> You appear to be running an older version of Coq, the definition you got
>> from the doc is as of Coq 8.7, the other is the previous definition.
>> See https://github.com/coq/coq/pull/1017
>> Gaëtan Gilbert
>> On 01/12/2017 21:38, Michel Levy wrote:
>>> In the doc, Standard Library, I read the good definition
>>> Ltac classical_right := match goal with
>>> |- ?X \/ _ => elim (classic X);intro;[left;trivial|right]
>>> end.
>>> But, after "Require Import Classical", when I execute
>>> Print Ltac_classical_right
>>> I read the following definition
>>> match goal with
>>> | _:_ |- ?X1 \/ _ => elim (classic X1); intro; [ left; trivial | right
>>> end.
>>> which seems to me incorrect. Am I right or wrong ?
>>> courriel :
>>> membres-liglab.imag.fr/michel.levy
>>> <http://membres-liglab.imag.fr/michel.levy>
> courriel :
- [Coq-Club] Module Classical, Ltac classical_right incorrect ?, Michel Levy, 12/01/2017
- Re: [Coq-Club] Module Classical, Ltac classical_right incorrect ?, Gaëtan Gilbert, 12/01/2017
- Re: [Coq-Club] Module Classical, Ltac classical_right incorrect ?, Michel Levy, 12/01/2017
- Re: [Coq-Club] Module Classical, Ltac classical_right incorrect ?, Christian Doczkal, 12/02/2017
