coq-club - [Coq-Club] Traversing Coq environment for declarations
  • To: Coq-Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Traversing Coq environment for declarations
  • Date: Tue, 5 Dec 2017 22:41:30 +0000
  • Accept-language: en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=kendroe AT hotmail.com; spf=Pass smtp.mailfrom=kendroe AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM03-CO1-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23:41kyqBBAp9SNU681DPI4UyQJP3N1i/DPJgcQr6AfoPdwSP39osbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6i760TlHMRLmcCFxO+69ToXVloG80/2405zVeQRBwjSnN+BcNhKz+CbcsM8bnYsqEKE8gk/Kr31EYeNb7WNvOVeanhK67cC1qs0wux9Msu4sopYTGZ7xeL41GORV
  • Spamdiagnosticmetadata: NSPM
  • Spamdiagnosticoutput: 1:99
I found (and adapted the following piece of code to traverse declarations in the current environment:
let print_full_pure_context () =
  let rec prec = function
  | ((_,kn),Lib.Leaf lobj)::rest ->
      let pp = match object_tag lobj with
      | "CONSTANT" ->
          let con = Global.constant_of_delta_kn kn in
          let cb = Global.lookup_constant con in
          let typ = ungeneralized_type_of_constant_type cb.const_type in
          hov 0 (
            match cb.const_body with
              | Undef _ ->
                str "Parameter " ++
                print_basename con ++ str " : " ++ cut () ++ pr_ltype typ
              | OpaqueDef lc ->
                str "Theorem " ++ print_basename con ++ cut () ++
                str " : " ++ pr_ltype typ ++ str "." ++ fnl () ++
                str "Proof " ++ pr_lconstr (Opaqueproof.force_proof (Global.opaque_tables ()) lc)
              | Def c ->
                str "Definition " ++ print_basename con ++ cut () ++
                str "  : " ++ pr_ltype typ ++ cut () ++ str " := " ++
                pr_lconstr (Mod_subst.force_constr c))
          ++ str "." ++ fnl () ++ fnl ()
      | "INDUCTIVE" ->
          let mind = Global.mind_of_delta_kn kn in
          let mib = Global.lookup_mind mind in
          pr_mutual_inductive_body (Global.env()) mind mib ++
      | "MODULE" ->
          (* TODO: make it reparsable *)
          let (mp,_,l) = repr_kn kn in
          print_module true (MPdot (mp,l)) ++ str "." ++ fnl () ++ fnl ()
      | "MODULE TYPE" ->
          print_modtype (MPdot (mp,l)) ++ str "." ++ fnl () ++ fnl ()
      | x -> (str "Unknown ") ++ (str x) ++ str " " ++ str (KerName.debug_to_string kn) ++ str "\n" ++ cut () ++ (mt ()) in
      prec rest ++ pp
  | ((_,kn),(Lib.CompilingLibrary (d,(m,d2))))::rest -> (str "Compiling Library ") ++ (str (DirPath.to_string d)) ++ (str " ") ++ (str (ModPath.to_string m)) ++ (str " ") ++ (str (DirPath.to_string d2)) ++ (str "\n") ++ prec rest
  | ((_,kn),(Lib.OpenedModule (a,b,c,d)))::rest -> (str "Opened module\n") ++ prec rest
  | ((_,kn),(Lib.ClosedModule ls))::rest -> (str "Closed module\n") ++ prec rest
  | ((_,kn),(Lib.OpenedSection (a,b)))::rest -> (str "Opened section\n") ++ prec rest
  | ((_,kn),(Lib.ClosedSection ls))::rest -> (str "Closed section\n") ++ prec rest
  | _ -> mt () in
  prec (Lib.contents ())
This code works well for printing out all the declarations in the top level environment.  However, if I have done something like:
Coq < Require Export AdvancedRewrite.advancedRewrite.
[Loading ML file theplug.cmxs ... done]
Coq < Require Export List.
Coq < Theorem x: 1=2.
1 subgoal
  1 = 2
x < arewrite.
Environment:
Compiling Library Top Top <>
Unknown REQUIRE Top._2
Unknown TOKEN Top._4
Unknown TOKEN Top._5
Unknown REQUIRE Top._3
Unknown REQUIRE Top._6
Unknown REQUIRE Top._7
Unknown REQUIRE Top._8
END
2 subgoals
  False
subgoal 2 is:
 False = (1 = 2)
x <
You will notice that I pick up all the top level declarations.  My "arewrite" tactic calls print_full_pure_context.  I would like to also pick up the declarations in all included libraries.  In this case, I would like to pick up the declarations in Arewrite.arewrite and List.  How can I do this?
                 - Ken
  • [Coq-Club] Traversing Coq environment for declarations, Kenneth Roe, 12/05/2017
