coq-club - Re: [Coq-Club] Question about canonical structures
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question about canonical structures
  • Date: Wed, 6 Dec 2017 00:48:52 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f174.google.com
  • Ironport-phdr: 9a23:TdGBnRF5tSN7FV4tEDQCYZ1GYnF86YWxBRYc798ds5kLTJ76ocuwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TXhpQIVTx74LE9+Ivn/UtrZiN3y3OSv8bXSZR9JjXyze+UhAg+xqFDzv9IRh8NNMKEq0VOdoHJTfOJZ32RzPgO7kBP158P295lmpXcD88k9/tJNBP2pN58zSqZVWWwr
Related question: Is there any existing work on reifying to (P)HOAS syntax trees via canonical structures?
On Wed, Dec 6, 2017 at 12:43 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
I have cargo-culted code for reifying flat syntax trees using canonical structures.  However, I have a question:
Why does canonical structure resolution fail when I require a constant to be applied to particular types.  That is, why does this work:
Inductive expr :=
| Const (v : nat)
| Add (x y : expr)
| LetIn (v : expr) (f : nat -> expr).
Axiom let_in : nat -> (nat -> nat) -> nat.
Axiom add : nat -> nat -> nat.
Fixpoint denote (e : expr) : nat
  := match e with
     | Const v => v
     | Add x y => denote x + denote y
     | LetIn v f => let_in (denote v) (fun x => denote (f x))
     end.
Structure tagged_nat := tag { untag :> nat }.
Structure reifed_of :=
  reify { nat_of : tagged_nat ; reified_nat_of :> expr }.
Definition const_tag := tag.
Definition let_in_tag := const_tag.
Canonical Structure add_tag n := let_in_tag n.
Canonical Structure reify_const n
  := reify (const_tag n) (Const n).
Canonical Structure reify_add x y
  := reify (add_tag (nat_of x + nat_of y)) (Add x y).
Canonical Structure reify_let_in v f
  := reify (let_in_tag (let_in (untag (nat_of v)) (fun x => nat_of (f x))))
           (LetIn (reified_nat_of v) (fun x => reified_nat_of (f x))).
Ltac reify_rhs _ :=
  etransitivity;
  [ | refine (eq_refl : untag (nat_of _) = _) ];
  lazymatch goal with
  | [ |- _ = untag (nat_of ?v) ]
    => transitivity (denote (reified_nat_of v))
  end;
  cbv [reify_add reify_const reify_let_in nat_of const_tag let_in_tag add_tag untag reified_nat_of];
  [ | cbv [denote]; reflexivity ].
Goal exists v, v = let_in 5 (fun x => let_in 6 (fun y => x + y)).
Proof.
  eexists.
  reify_rhs ().
  lazymatch goal with |- _ = denote (LetIn (Const 5) (fun x => LetIn (Const 6) (fun y => Add (Const x) (Const y)))) => idtac end.
  (* success *)
Abort.
but if I change Axiom let_in : nat -> (nat -> nat) -> nat. to Axiom let_in : forall {A B}, A -> (A -> B) -> B. then it fails (treats the whole thing as Const)?
Thanks,
Jason
