coq-club - Re: [Coq-Club] How strong is this deferredFix axiom?
  • From: Joachim Breitner <mail AT joachim-breitner.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] How strong is this deferredFix axiom?
  • Date: Wed, 06 Dec 2017 16:42:44 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
  • Ironport-phdr: 9a23:YvDpThCASz4NlB5LYk/LUyQJP3N1i/DPJgcQr6AfoPdwSP3zocbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6lCs4CQtGhTjOE8wD6y1X9eK14Xkn9y1rpbUekBDgCe3SbJ0NhS/6wvL5ecMho43CKE4wRvIpzNiYelX2WVlPxrHmh/94u+y+5do8yVV/vg7+s9cV6jgOag1G+8LRA86Onw4sZW4/SLIShGCsz5FCj0b
Hi,
thanks! That settles it quite conclusively :-)
JFTR, switching from
Axiom deferredFix : forall {a}, a -> (a -> a) -> a.
to
Axiom deferredFix : forall {a}, inhabited a -> (a -> a) -> a.
does not make a difference.
Thanks,
Joachim
Am Mittwoch, den 06.12.2017, 21:56 +0100 schrieb Gaëtan Gilbert:
> It's equivalent to epsilon.
> Let A : Type. Consider the function
> λ x : A + bool => match x with inl a => inl a | inr b => inr (not b)
> It has a fixed point if and only if A is inhabited, but A + bool is
> always inhabited (eg by inl true).
> In the attached file I use this to prove epsilon from your axioms.
> Gaëtan Gilbert
> On 06/12/2017 19:21, Joachim Breitner wrote:
> > Hi list,
> > I would like to be able to define recursive function and defer the
> > termination proof to later; this is especially interesting in the
> > context of generated Coq code with hs-to-coq[1].
> > What I currently use is
> > Axiom unsafeFix : forall {a}, (a -> a) -> a.
> > to define the recursive function, and then
> > Axiom unsafeFix_eq : forall {a} (f : a -> a),
> > unsafeFix f = f (unsafeFix f).
> > and to some extent and pragmatically speaking, this is not too bad if I
> > am disciplined in the use of these axioms[2].
> > But it is still unsatisfying, and if possible I’d like to avoid such
> > dangerous axioms. So I am wondering about these:
> > Axiom deferredFix_eq : forall {a} d (f : a -> a),
> > (exists x, f x = x) ->
> > deferredFix d f = f (deferredFix d f).
> > I believe these are consistent with basic Coq, because I can implement
> > them using the Hilbert Choice operator provided in the Coq standard
> > library:
> > Require Import Coq.Logic.ClassicalEpsilon.
> > Definition deferredFix : forall {a}, a -> (a -> a) -> a :=
> > fun {a} def f => epsilon (inhabits def) (fun x => f x = x).
> > Definition deferredFix_eq : forall {a} d (f : a -> a),
> > deferredFix d f = f (deferredFix d f) :=
> > fun a d f H =>
> > eq_sym (epsilon_spec (inhabits d) (fun x => f x = x) H).
> > But are they as strong as Hilbert’s epsilon, or are they weaker? How
> > weak are they?
> > Regards,
> > Joachim
> > [1] https://arxiv.org/abs/1711.09286
> > [2] https://www.joachim-breitner.de/blog/733-Existence_and_Termination
Joachim Breitner
http://www.joachim-breitner.de/
Attachment: signature.asc
Description: This is a digitally signed message part
