- From: Gabriel Scherer <gabriel.scherer AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Uncaught exception upon destructing a disjunction
- Date: Mon, 11 Dec 2017 09:18:28 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gabriel.scherer AT gmail.com; spf=Pass smtp.mailfrom=gabriel.scherer AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f169.google.com
- Ironport-phdr: 9a23:uu2gnxbqckQ3zxjFsqOB42L/LSx+4OfEezUN459isYplN5qZpsW9bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76xXcoFx7+LQt4IPjuUs6X1pzvlrP6x5qGSAJRzBG5fLk6eB6xtEDastQcqYpkMKc4jBXT9ChmYeNTkExhL0iSkhK03cyw8YRu6WwEtPsr7c9NVePhdKQ1V7FCJDsjOmExosbssE+QHkO0+nIAXzBOwVJzCA/f4US/B8+pvw==
Yes, this is a bug. I can reproduce it on 8.6, but I don't know about 8.7.
Note that the code you wrote is incorrect as the "as" part does not have the shape of a disjunction [ ... | ... ] as it should. You should writeOn Sun, Dec 10, 2017 at 6:58 AM, Bruno Le Floch <blflatex AT gmail.com> wrote:
Hi all,
Is this a bug? Given a file containing the four non-blank lines
following this paragraph, running "coqc <filename>.v" produces the
two-line error below. Coq version 8.5pl2 (August 2016) compiled with
OCaml 4.01.0.
Theorem test : forall A : Prop, A \/ A -> A.
Proof.
intros A.
intros H ; destruct H as H.
File "./Experiment3.v", line 4, characters 13-28:
Anomaly: Uncaught exception Not_found. Please report.
Best regards,
Bruno
- [Coq-Club] Uncaught exception upon destructing a disjunction, Bruno Le Floch, 12/10/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Ralf Jung, 12/11/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Bruno Le Floch, 12/12/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Ralf Jung, 12/12/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Bruno Le Floch, 12/15/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Gabriel Scherer, 12/11/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Merlin Göttlinger, 12/11/2017
- Re: [Coq-Club] Uncaught exception upon destructing a disjunction, Tej Chajed, 12/11/2017
