coq-club - Re: [Coq-Club] Macro for Ltac
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Macro for Ltac
  • Date: Thu, 14 Dec 2017 16:08:00 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-ot0-f172.google.com
  • Ironport-phdr: 9a23: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
Unfortunately there is currently no equivalent of ltac for commands.
The only way of defining new commands is via ocaml plugins AFAIK.
Best Regards,
Pierre
2017-12-14 14:42 GMT+01:00 Dominique Larchey-Wendling
<dominique.larchey-wendling AT loria.fr>:
> Thank you Pierre for your time.
> Actually, what I though about was textual manipulation of
> Coq code, not only terms or tactics ...
> For instance, consider a lemma foo such as for instance
> Lemma foo f x : f (f^n x) = f^(1+n) x.
> That I would like to incorporate into an autorewrite
> tactic.
> Ltac myauto := autorewrite with mydb.
> Hint Rewrite foo : mydb.
> The point is for instance that I do not want myauto to
> use foo for any f, but only for a specific f, which
> might change depending on the context.
> So
> Hint Rewrite (foo f) : mydb.
> But then, I would like a macro like :
> Marco myauto arg(f) :=
> Hint Rewrite (foo f) : mydb; autorewrite with mydb.
> So a macro is something that expands into Coq code.
> I agree it might lead to unreadable code before
> expansion. You can write unreadable (La)TeX code as
> well. But used wisely, it might help shrink code.
> Best,
> Dominique
> Le 14/12/2017 à 13:46, Pierre Courtieu a écrit :
>> I come back to this question after some thinking about it.
>> Indeed uconstr does not fit in the suggestion I made. Something you
>> may be able to do in some cases (but not in your case I guess, see
>> below) is to use the String type where you need some specific non
>> typable format.
>> Inductive args :=
>> Step: args
>> | Iter: nat -> args
>> | Hyp: forall (A:Type) (t:A), args
>> | Trans: String -> args. (* <--- here *)
>> and hopefully you can analyse the string character by character to
>> implement the behaviour you want.
>> BUT it seems your uconstr has subparts that you want to consider as
>> real coq terms, and I am not aware of a way to take a String and
>> transform it into a constr by giving it to the coq parser.
>> What are the possible forms of your uconstr arguments? Maybe you can
>> describe them in a inductive type.
>> Best,
>> Pierre
>> 2017-10-30 14:25 GMT+01:00 Dominique Larchey-Wendling
>>> Dear Pierre,
>>> Thx for the suggestion but there is a problem with
>>> the untyped argument <uconstr> which cannot be represented
>>> as a Coq typed term.
>>> Is there no way or extension for Tactic to manipulate
>>> text ?
>>> Dominique
>>> Le 30/10/2017 à 12:03, Pierre Courtieu a écrit :
>>>> Hi,
>>>> I guess you should define a tactic taking a list (coq lists) over some
>>>> inductive type describing the steps. Then some Tactic notation could get
>>>> you close to the syntax you want.
>>>> Pierre
>>>> Le lun. 30 oct. 2017 à 10:26, Dominique Larchey-Wendling
>>>> <mailto:dominique.larchey-wendling AT loria.fr>>
>>>> a écrit :
>>>> Dear all,
>>>> I am wondering if there is a way to define macros within the
>>>> tactic language.
>>>> For instance, consider that I have already defined
>>>> tactic notations such as:
>>>> wcbv step
>>>> wcbv iter <integer>
>>>> wcbv hyp
>>>> wcbv trans <uconstr>
>>>> Then I would like to be able to write
>>>> wcbv step, hyp, hyp, trans (t @ a), iter 2.
>>>> instead of
>>>> wcbv step; do 2 wcbv hyp; wcbv trans (t @ a); wcbv iter 2.
>>>> Can I do this using Ltac and Tactic Notation ?
>>>> Because it seems neither can input <text> as an
>>>> argument (like latex or metapost macros would do)
>>>> Thanks very much in advance for any hint
>>>> Dominique
