- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Makefile targets
- Date: Fri, 15 Dec 2017 16:58:27 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay5-d.mail.gandi.net
- Ironport-phdr: 9a23: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
coqbinaries tools pluginsopt?
Hard to say without knowing what kind of error you get.
Gaëtan Gilbert
On 15/12/2017 16:52, N. Raghavendra wrote:
I have a Coq development, for which I am using coqtop / coqc with
the -noinit option, and the commands
Declare ML Module "ltac_plugin".
Global Set Default Proof Mode "Classic".
in the source files. Right now, I am building Coq for this project
using "make coqbinaries states tools". This still builds Prelude.vo,
which I don't need because I use the "-noinit" option. So, is there a
set of Makefile targets for building Coq, which gives me just
coqbinaries, tools, and the ltac plugin? (I have tried "make
coqbinaries ltac tools", but my files don't compile with the resulting
build.)
Thanks and best regards,
Raghu.
N. Raghavendra
<raghu AT hri.res.in>,
http://www.retrotexts.net/
Harish-Chandra Research Institute, http://www.hri.res.in/
- [Coq-Club] Makefile targets, N. Raghavendra, 12/15/2017
- Re: [Coq-Club] Makefile targets, Gaëtan Gilbert, 12/15/2017
- Re: [Coq-Club] Makefile targets, N. Raghavendra, 12/15/2017
- Re: [Coq-Club] Makefile targets, Emilio Jesús Gallego Arias, 12/15/2017
