coq-club - Re: [Coq-Club] [TYPES/announce] Tenure-Track Research and Teaching Positions at University of British Columbia, Vancouver, Canada
  • To: Ronald Garcia <rxg AT cs.ubc.ca>, types-list AT lists.seas.upenn.edu, coq-club AT inria.fr, categories AT mta.ca
  • Subject: Re: [Coq-Club] [TYPES/announce] Tenure-Track Research and Teaching Positions at University of British Columbia, Vancouver, Canada
  • Date: Sun, 31 Dec 2017 20:37:07 +0800
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=1337777.ooo AT gmail.com; spf=Pass smtp.mailfrom=1337777.ooo AT gmail.com; spf=None smtp.helo=postmaster AT mail-it0-f65.google.com
  • Ironport-phdr: 9a23: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
Proph
https://gitee.com/OOO1337777/cartier/blob/master/cartierSolution3.v
solves half of some question of Cartier which is how to program
grammatical polymorph metafunctors-full-subcategory
containing-equalizers generated by some views ( "complete" ) ...
The ends is to start from some generating/views data and then to add
equalizers of morphisms ; but where are those equalizers ? Oneself
could get them as metafunctors on this generating data, as long as
oneself grammatically distinguishes whatever-is-interesting .
In contrast from the earlier grammatical presentation of
pairing-projections (product), now the equalizer-objects do depend on
the morphisms . BUT THIS DEPENDENCE NEED-NOT BE GRAMMATICAL ! This
dependence could be expressed via the sense-decoding ( "Yoneda" ) of
the grammatical morphisms .
The grammatical objects/morphisms are simultaneously-mutually
presented with their sense-decoding ; this could be done via some
common inductive-recursive presentation or alternatively by inferring
the sense-decoding computation into extra indexes of the type-family
of the object/morphisms .
The conversion-relation shall convert across two morphisms whose
sense-decoding indexes are not syntactically/grammatically-the-same.
But oneself does show that, by logical-deduction, these two
sense-decoding are indeed propositionally equal ( "soundness lemma" )
Finally, some linear total/asymptotic grade is defined on the
morphisms and the tactics-automated degradation lemma shows that each
of the conversion indeed degrades the redex morphism .
For instant first impression , the conversion-relation constructor
which says that the inclusion/restriction (projection) morphisms
cancels the corestriction (pairing) morphism , is written as :
#+BEGIN_EXAMPLE
| Pairing_Project1 :
forall Yoneda00_L Yoneda01_L (L : @obCoMod Yoneda00_L Yoneda01_L)
Yoneda00_F Yoneda01_F (F : @obCoMod Yoneda00_F Yoneda01_F)
Yoneda00_G Yoneda01_G (G : @obCoMod Yoneda00_G Yoneda01_G),
forall Yoneda10_transfL (transfL : 'CoMod(0 F ~> G @ Yoneda10_transfL )0)
Yoneda10_transfR (transfR : 'CoMod(0 F ~> G @ Yoneda10_transfR )0),
forall Yoneda10_ff (ff : 'CoMod(0 L ~> F @ Yoneda10_ff )0),
forall (Yoneda10_ff_eq :
forall A : obIndexer, proj1_sig Yoneda10_transfL A \o
proj1_sig Yoneda10_ff A
=1 proj1_sig Yoneda10_transfR A \o proj1_sig
Yoneda10_ff A),
forall ( _transfL : 'CoMod(0 F ~> G @ Yoneda10_transfL )0 )
( _transfR : 'CoMod(0 F ~> G @ Yoneda10_transfR )0 )
Yoneda00_Z Yoneda01_Z (Z : @obCoMod Yoneda00_Z Yoneda01_Z)
Yoneda10_zz (zz : 'CoMod(0 F ~> Z @ Yoneda10_zz )0),
( ( ff o>CoMod zz )
: 'CoMod(0 L ~> Z @ Yoneda10_PolyCoMod Yoneda10_ff Yoneda10_zz )0 )
<~~ ( ( ( << ff ,CoMod Yoneda10_ff_eq @ transfL , transfR >> )
o>CoMod ( ~_1 @ _transfL , _transfR o>CoMod zz ) )
: 'CoMod(0 L ~> Z @ Yoneda10_PolyCoMod (Yoneda10_Pairing
Yoneda10_ff_eq)
(Yoneda10_Project1 Yoneda10_transfL Yoneda10_transfR Yoneda10_zz)
)0 )
#+END_EXAMPLE
KEYWORDS : 1337777.OOO ; COQ ; cut-elimination ; equalizers ;
polymorph metafunctors-grammar ; modos
OUTLINE :
* Generating-views data
* Grammatical presentation of objects and morphisms , with
sense-decoding as metafunctors and metatransformations
** Grammatical presentation of objects
** Grammatical presentation of morphisms
* Grammatical conversions of morphisms , which infer the same sense-decoding
** Grammatical conversions of morphisms
** Same sense-decoding for convertible morphisms
** Linear total/asymptotic grade and the degradation lemma
* Solution
** Solution morphisms without polymorphism
** Destruction of morphisms with inner-instantiation of object-indexes
* Polymorphism/cut-elimination by
computational/total/asymptotic/reduction/(multi-step) resolution
EPILOGUE : Now there is enough data (for multiple masters-engineering)
to confirm the presence of some MODOS grammar, which is some style of
"substructural topos" ... where oneself could present grammatical
polymorph views-data ( "sheaves" ) , grammatical polymorph
generating-views ( "presentable category" ) , grammatical polymorph
internal functors ( "internal category" ) , grammatical polymorph
images ( "regular category" ) , grammatical polymorph unions (
"coherent category" ) ...
Memo ( "prealables d'un debat" ) ref the unavoidable question : what
is the ends / added-value / product in mathematics ? The ends are
commonly described as research , which is the engineering of some
computational logical computer program or physical prototype (
"correct" ) , and education , which is the knowing-and-teaching of
random-moment dia-para-computalogical discoveries ( "ideas" ) .
But where is the money/pay ? Surprisingly even persons capable of very
complex mathematics can "bug" (
forced-fool-and-theft/lie/falsification ) on such small questions ...
reacting with completely pre-formated one-liners .
- whether public review of mathematical-ends is some unlimited
creation of resource/money/pay ? ( for example ,
https://github.com/1337777/cartier/issues )
- whether public-university registered-students shall have public
choice of who is their paid-teachers and where is their paid
classroom/videostream/book ? ( for example ,
https://www.youtube.com/watch?v=BhWHxiqQzrI&t=26m11s )
- whether if 99% of transfer of value occurs via information-knowledge
then for sure 99% of theft occurs via information-knowledge ? ( for
example , promotion/publisher by some interdependent-tribalistic
hidden "reviewer" is qualifiable as misappropriation of public funds )
... or is ubc not public ?
BUY RECURSIVE T-SQUARE paypal.me/1337777 ; 微信支付
2796386464 AT qq.com
eth 0x54810dcb93b37DBE874694407f78959Fa222D920 ; amazon
amazon.com/hz/wishlist/ls/28SN02HR4EB8W ; irc #OOO1337777
  • Re: [Coq-Club] [TYPES/announce] Tenure-Track Research and Teaching Positions at University of British Columbia, Vancouver, Canada, 1337777.OOO, 12/31/2017
