- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A reduction for the nat recursor
- Date: Wed, 3 Jan 2018 08:02:27 +0100
Hi. About eta for iteration, see for instance "A NOTE ON REWRITING THEORY FOR UNIQUENESS OF ITERATION" of M. Okada and P. Scott, Theory and Applications of Categories, 6, 47-64 in 2000: The rule is: f = R a h where f : A x nat -> B, R is the recursor on nat and a = \x.f x 0, if for all x and y, f x (S n) = h x n (f x n). "(i) It is undecidable, (ii) Church-Rosser fails, although ground Church-Rosser holds, (iii) strong normalization (termination) is still valid. This entails the undecidability of the coherence problem for
cartesian closed categories with strong natural numbers objects,
as well as providing a natural example of the following
computational paradigm: a non-CR, ground CR, undecidable,
terminating rewriting system." Frédéric. Le 03/01/2018 à 03:13, Jasper Hugunin a
écrit :
Hi Cody,
Thanks for your response.
Neither of the rules you mentioned seem to quite match what
I am looking for (though maybe they imply it).
As I understand it, eta for inductives reduces (fix id n :=
match n with O => O | S m => S (id m) end) to (fun n
=> n),
or reduces (match n with O => O | S m => S m end) to
n.
Neither of these seem to apply when defining a function
(nat -> A).
Commutative conversions allow to move the application of a
function across a match (into and out of the branches).
But there is no function applied to the match in (fix shift n := match n with O => a |
S m => shift m end),
and no shared function that
I see applied to the branches (a) and (shift m).
Perhaps you know of a more
general meaning for these rules or some tricky set of
rewrites to use to derive it?
I'll attach my example
below. Modulo this reduction, it is an implementation of
coinductive types from nat, pi, and sigma,
with an anamorphism and
eliminator such that the eliminator computes on the
anamorphism.
Under the univalence axiom,
these types should be equivalent to the ones in the paper
below,
which were shown to have the
correct equality types.
The main ideas are all in
NON-WELLFOUNDED TREES IN
HOMOTOPY TYPE THEORY
BY: BENEDIKT AHRENS, PAOLO
CAPRIOTTI, AND RÉGIS SPADOTTI
<https://hott.github.io/M-types/m-types.pdf>,
this development just
improves the computational behavior.
I don't have much hope for adding this reduction to Coq,
since it seems very specific to nat,
but I was thinking it could be interesting to develop a
type theory with such a rule,
and then get coinductive types for free.
Best,
- Jasper Hugunin
On Tue, Jan 2, 2018 at 9:47 PM, roux
cody <cody.roux AT gmail.com>
wrote:
Hi Jasper!
This rule is sometimes called "eta for
inductives" or "commutative conversions". In some
versions it may break confluence, and in general
is quite difficult to implement in Coq.On Tue, Jan 2, 2018 at 2:20
AM, Jasper Hugunin <jasperh AT cs.washington.edu>
wrote:
Hello,
I ran into the following function:
(fix shift n := match n with O => a | S
m => shift m end) : nat -> A
which clearly on any concrete n reduces to
a.
It would be very convenient if this was
judgmentally equal to (fun _ => a).
Of course, this is not implemented in Coq,
but I haven't been able find any references
discussing such a reduction. Does anyone know
what the cost of adding such a reduction would
be?
(does it break decidable type-checking, or
introduce unreasonable computational
overhead?)
Where this comes from, is that I actually
have a family of types A : nat -> Type,
along with
forall n, A n = A (S n), and a0 : A 0. My
function then looks like (fun n => nat_rect
A a0 (coerce) n),
but for some specific instances A is
actually independent of n, and the equalities
are eq_refl.
In the general case, I don't see how to do
a useful reduction, but when given such nice
data I would
have liked to return just a, independent of
n.
- Jasper Hugunin
- [Coq-Club] A reduction for the nat recursor, Jasper Hugunin, 01/02/2018
- Re: [Coq-Club] A reduction for the nat recursor, roux cody, 01/02/2018
- Re: [Coq-Club] A reduction for the nat recursor, Jasper Hugunin, 01/03/2018
- Re: [Coq-Club] A reduction for the nat recursor, Frédéric Blanqui, 01/03/2018
- Re: [Coq-Club] A reduction for the nat recursor, Felix Rech, 01/08/2018
