coq-club - Re: [Coq-Club] Mutual Fixpoints into mutual inductive types
  • From: Joachim Breitner <mail AT joachim-breitner.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Mutual Fixpoints into mutual inductive types
  • Date: Mon, 08 Jan 2018 16:25:21 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
  • Ironport-phdr: 9a23:vZQw4Rz8iC0ZEHLXCy+O+j09IxM/srCxBDY+r6Qd1OMRIJqq85mqBkHD//Il1AaPAd2Craocw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94HObwlSmDaxfa55IQmrownWqsQYm5ZpJLwryhvOrHtIeuBWyn1tKFmOgRvy5dq+8YB6/ShItP0v68BPUaPhf6QlVrNYFygpM3o05MLwqxbOSxaE62YGXWUXlhpIBBXF7A3/U5zsvCb2qvZx1S+HNsDwULs6Wymt771zRRHrlSkJNyA3/m/Vhcx+kK1Vpx2uqgdww4LIeoyYLuBzcr/ZcN4cWGFPXtxRVytEAo6ka4UPCPAOMvpYr4n8olsFsAazBROyC+Pu1j9IgGH53bcn2OkmFAHJxg0gH9YVvXTWq9X6LrsdUeC0zKnN1DnMdOlW1in86IjUdBAuv+uMUahtfsXP0EQiER7OgFuXqYzgJTyV1+INvnCZ7+pnT+2gl24nqwB0ojS23cgskJfGhoMJylDC6yp52pw5KsCmR0Jjbt6kEYdQtyGHN4RtWM8tX2ZouCM8x7YbupC7ZDAHxIklyhPecfCKd5KE7gz+WOufOzt0mXxodby5ih2v60av0Pf8WdOx0FtSripKjN3MtncV2hzT9MeHUP598Vm62TqVzADc9PtEIV4qmqrBMZEhx6Q/moAOvkvdBiP2mUP2g7GKdkg85+Sl6eXqbq/iq5OGKYN4lw/zPr4zlsGxD+k0Kg0OUHKa+eS42r3j50r5QLBSg/0ziKbZsZTaKN8Zpq6+GQBazoYj6xe6Dzu/y9sYh2cILFNZeBKBkYfpIUvCL+3mAvunmVSjjC9rx+zaPr3mGpjCMn/DkK74cblh705c1RE8wMtE55NUD7EBOOj8VlXwtNzeFB85Mha7z/zpCNVnhcsiXjeEBbbcO6fPu3eJ4PguKq+Cftw7ojH4ftoi7vXujHpxs0UQfLWv0IFfPHWxH/BOIUKQanrth5ILC2oLogwzVqrmhQvRAnZoe3+uUvdktXkAA4W8ANKbSw==
Hi,
I am a bit lost. Can you share a complete minimal working example of
the Coq code that you hoped to work, and also the variant that you
wrote that actually work?
Cheers,
Joachim
Am Montag, den 08.01.2018, 10:53 +0000 schrieb Merlin Göttlinger:
> Hi,
> Joachim Breitner
> schrieb am Mo., 8. Jan. 2018 um 11:04 Uhr:
> > Hi,
> > Am Montag, den 08.01.2018, 08:23 +0000 schrieb Merlin Göttlinger:
> > > sure. My guess would be that I messed up the encoding of the
> > > hierarchy and the fmap call in the implementation of traverse is
> > > therefore not resolved to be be the Vector.map call.
> > > https://gist.github.com/mgttlinger/db35a3748f1dfe68c152678f9a714c06
> > ah, you are using features I have not played around with (e.g. :>, and
> > default definitions in a record).
> I just tried implementing traverse like this:
> Definition traverse `{T: Traversable} `{@Applicative G} {t u} : (t -> G
> u) -> F t -> G (F u) :=
> let f := T _ (t_f__) in fun f ft => sequence (fmap f ft).
> As to not rely on the default implementation in the record. That didn't
> change anything.
> Implementing traverse at the instance creation also didn't help.
> I suspect it could be because my implementation is defined interactively.
> Definition vSequence {G} {n} `{Applicative G} : forall T, Vector.t (G T) n
> -> G (Vector.t T n).
> intros. induction X; pose proof _f as f; pose proof _p as p. apply
> pure; trivial. apply (@point (fun f => Vector.t f 0) _ _). eapply ap. apply
> (fmap (fun a b => a :: b) h). exact IHX.
> Defined.
> This is the definition. The Instance is then essentially
> Definition vTraversable {G} {n} : @Traversable__Dict (fun t => Vector.t t
> n) G := {| sequence__ _ := vSequence;
> Global Instance vector_Traversable {n} {G} : @Traversable (fun t =>
> Vector.t t n) G := fun r f => f vTraversable.
> > Does it work if you do not give the definition of traverse__ in the
> > Record definition, and instead give it during your Instance? Where is
> > your Instance?
> > > What is the "local go" pattern? A quick google lead me only to things
> > > related to Go-lang.
> > There might be a better name. It is the problem that nested recursion
> > through map defined like
> > Fixpoint map f xs := match xs with
> > | x :: ys => f x :: map f ys end.
> > fails but
> > Definition map f :=
> > fix go xs := match xs with
> > | x :: ys => f x :: go ys end.
> > works.
> Good to know.
> Cheers,
> Merlin
Joachim Breitner
http://www.joachim-breitner.de/
Attachment: signature.asc
Description: This is a digitally signed message part
