- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coq-projective-geometry package
- Date: Fri, 19 Jan 2018 20:26:32 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay4-d.mail.gandi.net
- Ironport-phdr: 9a23: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
That project seems to have branches for various Coq versions. In the 8.4 branch that position in the failing file is not at the end of the proof, suggesting that the most recent version of the development is not compatible with 8.4.
Try the 8.4 branch or a newer Coq.
Gaëtan Gilbert
On 19/01/2018 19:51, Anthony Bordg wrote:
Hi,
I would like to build the coq package on projective geometry <https://github.com/coq-contribs/projective-geometry> to go through the proofs in the various files with Proof General or coqIDE. But using the make command I got the following error:
File "/home/anthony/projective-geometry/Plane/projective_plane_to_Heyting_projective_plane.v", line 146, characters 0-4:
Error: Attempt to save an incomplete proof
Makefile.coq:245 : la recette pour la cible « Plane/projective_plane_to_Heyting_projective_plane.vo » a échouée
make[1]: *** [Plane/projective_plane_to_Heyting_projective_plane.vo] Erreur 1
make[1] : on quitte le répertoire « /home/anthony/projective-geometry »
Makefile:2 : la recette pour la cible « all » a échouée
make: *** [all] Erreur 2
However, the aforementioned proof does not seem to be incomplete. I'm using coq v.8.4pl4 on Ubuntu 16.04 LTS. Any help would be welcome.
Regards
Anthony
*PhD. Anthony Bordg
*Research Associate
*Cambridge University, UK
https://sites.google.com/site/anthonybordg/*
- [Coq-Club] coq-projective-geometry package, Anthony Bordg, 01/19/2018
- Re: [Coq-Club] coq-projective-geometry package, Gaëtan Gilbert, 01/19/2018
- Re: [Coq-Club] coq-projective-geometry package, Ravi Bajaj, 01/19/2018
- Re: [Coq-Club] coq-projective-geometry package, Anthony Bordg, 01/19/2018
