coq-club - Re: [Coq-Club] 64-bit integers
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] 64-bit integers
  • Date: Thu, 25 Jan 2018 14:17:05 -0800
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=vadim.zaliva AT west.cmu.edu; spf=Pass smtp.mailfrom=vadim.zaliva AT west.cmu.edu; spf=None smtp.helo=postmaster AT mail-ot0-f172.google.com
  • Ironport-phdr: 9a23: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
Are there any plans to distribute this library as an OPAM package? What would be the recommended way to use it in somebody's Coq project?
Vadim
CMU ECE PhD candidate
Mobile/WhatsApp: +1(510)220-1060
On Sat, Jan 13, 2018 at 8:09 AM, Xavier Leroy <Xavier.Leroy AT inria.fr> wrote:
On 01/12/2018 11:32 PM, Eddy Westbrook wrote:
> Is there already a type of 64-bit integers in the Coq standard library? Or at least 32-bit integers? I see some evidence of these in the documentation of some of the numeric modules, but I don’t really understand them…
Maybe you stumbled on the 31-bit machine integers that are used in one of the implementations of (mathematical, arbitrary-precision) integers from Coq's standard library.  But those 31-bit integers are not really usable on their own.
For N-bit integer arithmetic in the style of C or Java, you could use CompCert's "Integers" library,
   http://compcert.inria.fr/doc/html/Integers.html
It defines (as a parameterized module) N-bit integers and their signed and unsigned arithmetic and logical operations, plus a whole lot of theorems about those operations.  Instantiations for N=8, N=32 and N=64 are provided, with extra operations and theorems relating 32- and 64-bit integers.
- Xavier Leroy
