- From: Armaël Guéneau <armael.gueneau AT ens-lyon.fr>
- To: coq-club AT inria.fr, Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- Subject: Re: [Coq-Club] fun+pattern and primitive projections
- Date: Fri, 9 Feb 2018 11:49:21 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=armael.gueneau AT ens-lyon.fr; spf=Neutral smtp.mailfrom=armael.gueneau AT ens-lyon.fr; spf=None smtp.helo=postmaster AT labbe.ens-lyon.fr
- Ironport-phdr: 9a23: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
Thank you for the replies. I've opened an issue to keep track of this:
https://github.com/coq/coq/issues/6723
Cheers,
Armaël
On 07/02/2018 14:47, Robbert Krebbers wrote:
> +1 for more a more clever desugaring.
> See also https://github.com/coq/coq/issues/5701
> On 02/07/2018 01:46 PM, Matthieu Sozeau wrote:
>> Hi,
>> It think it would be rather hopeless to try and invert the projections at
>> pretty printing time to everyone’s contentment. However, it might be
>> possible to use a more clever desugarring that let-binds the projections
>> (potentially with specific constants to avoid simpl reducing them but
>> still
>> allowing unification to succeed) and invert those.
>> Cheers,
>> — Matthieu
>> Le mer. 7 févr. 2018 à 13:26, Armaël Guéneau
>> a
>> écrit :
>>> Hi everyone,
>>> I am facing an issue related to the use of "fun '(_,_) => ..." with
>>> primitive projections. It works well when writing goals & lemmas, but
>>> at pretty-printing time, only the desugared version is printed, which
>>> quickly gets unreadable. I'm wondering if other people have already
>>> faced this issue, and if there's a known workaround to improve the
>>> pretty-printing -- or if I should maybe open a feature request on
>>> Coq's issue tracker.
>>> Here follows a more detailed description of the issue.
>>> Let's assume for the sake of the example a predicate on functions of
>>> type "A -> nat", and a compatibility lemma about P and +, which holds
>>> for any A.
>>> Parameter P : forall A, (A -> nat) -> Prop.
>>> Hypothesis P_add : forall A f g,
>>> P A f -> P A g -> P A (fun x => f x + g x).
>>> Now consider the following goal, where A is (nat * nat):
>>> Goal P (nat * nat) (fun '(x,y) => x + y).
>>> Fail apply P_add.
>>> With the standard pairs, I cannot call "apply P_add" -- the goal does
>>> not unify with the conclusion of the lemma, since (fun '(x,y) => x +
>>> y) is sugar for (fun p => let (x,y) := p in x + y). One solution would
>>> be to restate the goal as:
>>> Goal P (nat * nat) (fun p => (fst p) + (snd p)).
>>> apply P_add
>>> which I find inconvienient; I like being able to give names to the
>>> components of the tuple, especially with bigger arities (where one
>>> would have to instead write (fst (fst p)) and such).
>>> Matthieu Sozeau pointed out to me that an other solution is to use
>>> primitive projections: this way, one can still use the "fun '(x,y) =>
>>> ..." sugar, which gets desugared to uses of fst and snd.
>>> Set Primitive Projections.
>>> Unset Printing Primitive Projection Compatibility.
>>> (* required for projections to actually be displayed *)
>>> Record myprod A B := mypair { myfst : A; mysnd : B }.
>>> Arguments mypair {A B} _ _.
>>> Arguments myfst {A B} _.
>>> Arguments mysnd {A B} _.
>>> Notation "x ** y" := (myprod x y) (at level 80): type_scope.
>>> Notation "( x , y , .. , z )" := (mypair .. (mypair x y) .. z).
>>> Goal P (nat ** nat) (fun '(x,y) => x + y).
>>> apply P_add.
>>> This works, which is nice. (fun '(x,y) => x + y) is desugared to (fun
>>> pat : nat ** nat => (myfst pat) + (mysnd pat)), and P_add can be
>>> applied directly.
>>> However, this desugaring is made apparent to the user: when proving
>>> the goal, the user works with the desugared version of the goal &
>>> hypothesis. This quickly gets unreadable in my opinion: there's a
>>> "pat" variable that I cannot name, the names "x" and "y" are lost, and
>>> with tuples of arity > 2, they are replaced by nested projections (eg
>>> (fst (fst pat))) which I find really hard to keep track of.
>>> I'm wondering if someone already faced this issue.
>>> If there is no workaround for now, could one think of a better
>>> pretty-printer? I'm thinking of attaching to a "fun" the fact that it
>>> comes from a "fun '(_,_) => ..." sugar, along with information about
>>> the user-provided names; and then trying to pretty-print the
>>> fun+projections using the "fun '(_,_) => ..." sugar and the user
>>> names.
>>> If this seems a reasonable proposal I could submit a feature request
>>> on Coq's issue tracker.
>>> Cheers, and thanks for reading,
>>> Armaël
- [Coq-Club] fun+pattern and primitive projections, Armaël Guéneau, 02/07/2018
- Re: [Coq-Club] fun+pattern and primitive projections, Matthieu Sozeau, 02/07/2018
- Re: [Coq-Club] fun+pattern and primitive projections, Robbert Krebbers, 02/07/2018
- Re: [Coq-Club] fun+pattern and primitive projections, Armaël Guéneau, 02/09/2018
