coq-club - Re: [Coq-Club] Bug w.r.t. Let Fixpoint & Section visibility
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Bug w.r.t. Let Fixpoint & Section visibility
  • Date: Thu, 15 Feb 2018 14:36:08 +0100
  • Organization: LORIA
Done.
D.
> Would you mind reporting at https://github.com/coq/coq/issues ?
> Thanks!
> Maxime.
> On 02/15/2018 02:17 PM, Dominique Larchey-Wendling wrote:
>> Hi all,
>> Maybe this is a feature but the following example shows a
>> Let Fixpoint construct leaking out of a Section. Is this the
>> desired behaviour (tested under 8.6 and 8.7.1) ?
>> Section visibility.
>> Let Fixpoint ev n := match n with 0 => true | S n => od n end
>> with od n := match n with 0 => false | S n => ev n end.
>> Let Fixpoint ev' (n : nat) : bool
>> with od' (n : nat) : bool.
>> Proof.
>> exact (match n with 0 => true | S n => od' n end).
>> exact (match n with 0 => false | S n => ev' n end).
>> Defined.
>> Let my_even := ev.
>> End visibility.
>> Check ev'. (* succeeds (unexpected) *)
>> Check my_even. (* succeeds as expected *)
>> Check ev. (* fail as expected *)
>> I do not see why ev & ev' are treated differently?
>> Thx in advance,
>> Dominique
