coq-club - Re: [Coq-Club] Operations on boolean vector : shift / mask
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Operations on boolean vector : shift / mask
  • Date: Wed, 21 Feb 2018 16:07:46 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=vincent.siles AT ens-lyon.org; spf=None smtp.mailfrom=SRS0=hSKG=FP=ens-lyon.org=vincent.siles AT bounce.ens-lyon.org; spf=Pass smtp.helo=postmaster AT sonata.ens-lyon.org
  • Ironport-phdr: 9a23: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
I see. Clever use of rev, I'll try to make it work for my case !
2018-02-21 14:59 GMT+01:00 Lars Rasmusson <lars.rasmusson AT ri.se>:
If by "shift" you mean "rotate", perhaps you can build on 'rot1', which puts the last element first...
Require Import Vector.
Definition last_n {T m} (v:Vector.t T m) n (H:n<=m) := rev ((take n H (rev v))).
Definition rot1 {T n} (v:Vector.t T (S n)) := append (last_n v 1 (le_n_S _ _ (le_0_n _))) (take n (le_S _ _ (le_n _)) v).
On 20 Feb 2018, at 10:25 , Vincent <vincent.siles AT gmail.com> wrote:
Hi !
I'm trying to write some properties about N bit integers in Coq (N = 54 and 27), and I am considering the 'mask' and 'left/right shifts'.
From the library [1], I see that I can use 'trunc' to implement my 'mask' operation, but I don't see anything I could use to implement 'right shift'. My first goal is to prove something like:
append (n & MASK27) (n >> 27) == n
Did I miss something in the lib or am I looking at the from library ?
Best,
V.
[1] https://coq.inria.fr/library/Coq.Vectors.VectorDef.html#
