- To: coq-club AT inria.fr
- Subject: [Coq-Club] research engineer (postdoc) position at MSR-Inria Joint Centre
- Date: Mon, 5 Mar 2018 18:15:52 +0100
Research team: Tools for Proofs, MSR-INRIA Joint Centre
The Microsoft Research-INRIA Joint Centre is offering a 24-month position for
a
research engineer to contribute to the design and further development of the
TLA+ Proof System (TLAPS, http://msr-inria.com/projects/tools-for-proofs).
Research Context
TLA+ is a language for specifying and reasoning about systems, including
concurrent and distributed systems. It is based on first-order logic, set
theory, and temporal logic. TLA+ and its tools have been used in industry for
more than a decade. More recently, we have extended TLA+ by a language for
writing structured formal proofs and have developed TLAPS, a proof checker
that
contains an interpreter for the proof language and interfaces with different
back-end provers, including SMT solvers, the tableau prover Zenon that
supports
set-theoretic constructions, and a declarative encoding of TLA+ set theory as
an object logic in the logical framework Isabelle. TLAPS is integrated into
the
TLA+ Toolbox, an IDE for TLA+ (http://lamport.azurewebsites.net/tla/tla.html).
Although it is still under active development, TLAPS is already quite powerful
and has been used for several verification projects, in particular in the
realm
of distributed algorithms (e.g.,
http://lamport.azurewebsites.net/tla/byzpaxos.html).
The current version of TLAPS handles the "action" part of TLA+: first-order
formulas with primed and unprimed variables that represent the values of a
variable before and after a transition. It also supports the propositional
fragment of temporal logic. This fragment is enough for proving safety
properties (invariants and step simulation). We have initiated a complete
rewrite of the code base, with the aim of providing support for module
instantiation and for the full temporal logic of TLA+, which will allow us to
prove liveness and refinement properties.
Description of the activity of the research engineer
The research engineer (post-doctoral) position is funded for 24 months by the
Microsoft Research - Inria Joint Centre. You
will work together with the members of the TLA+ project, including Damien
Doligez, Leslie Lamport, and Stephan Merz on extending the TLA+ Proof System.
Your main objective will be to complete the rewrite of the existing version of
TLAPS so that it can be released to users of the prover. You will also be able
to work on extensions of existing functionality, including the following
items:
- Module instantiation. The TLA+ language contains a module system, and
modules
can have constant and variable parameters in order to make them generic and
reusable. When a module is instantiated, parameters can be replaced by
constant- and state-level expressions, and these instantiations must be
taken
into account when generating proof obligations for back-end provers.
- Handling temporal logic. Proofs of liveness properties need support for
reasoning about first-order temporal logic, such as induction over
well-founded orderings. Fairness hypotheses require reasoning over the
enabledness of actions. New backend provers need to be set up and integrated
into TLAPS for carrying out these proofs.
- Improved backend provers. The current backend provers provide decent support
for proof obligations mixing first-order logic, elementary set theory,
functions, and integer arithmetic. Reasoning about other important data
structures such as finite sequences requires low-level user interaction. We
are interested in exploiting advances in automatic deduction techniques,
such
as support for relevant theories in SMT solvers, for enabling a higher
degree
of automation of such proof steps.
- Rigorous validation of soundness. Computing proof obligations involves some
subtle transformations, such as distributing the prime operator of TLA+ or
handling instantiated ENABLED expressions. We are working on a precise
definition of the semantics of the proof language that would help us ensure
the soundness of these transformations and give guidelines to the
implementation.
- Checking SMT proofs. The SMT backend handles most of the proof obligations
that occur in practice. The current version of TLAPS assumes the external
SMT
solver to be correct, but we are interested in reconstructing proofs
provided
by SMT solvers within Isabelle/TLA+. The Zenon backend already benefits from
proof reconstruction.
- Performance issues. Proof projects can be large, and TLAPS implements
mechanisms, such as fingerprinting proof obligations, that are intended to
make the tool scale. Performance bottlenecks should be monitored and
avoided,
whenever possible.
- Case studies and proof libraries. Our work on TLAPS is validated by carrying
out case studies, and we provide libraries of lemmas that are useful for
many
proof projects.
We do not expect to be able to address all of these issues within 24 months.
The
choice of items will be made jointly with the research engineer, also
depending
on his or her interests and background.
Skills and profile of the candidate
You should hold a PhD degree in computer science and have solid knowledge of
mathematical logic, as well as implementation skills related to symbolic
theorem
proving. TLAPS is mainly implemented in OCaml, but some Java programming will
be
necessary for interfacing TLAPS with the other TLA+ tools. Experience with
temporal and modal logics, with interactive theorem provers or with Eclipse
could be valuable.
Work on TLAPS provides the opportunity to learn about issues of using
deductive
verification in practice, and there are possibilities to produce publishable
research. However, the main focus is on the implementation of components of
our
tool chain that are missing or need improvement.
Given the geographical distribution of the members of the team, we highly
value
a good balance between the ability to work in a team and the capacity to
propose
initiatives.
Location
The research engineer can choose between working at the Microsoft Research -
Inria Joint Centre in Paris or at the LORIA laboratory in Nancy.
Compensation
The salary will be between 2900 and 3800 euros, depending on qualifications
and experience.
Duration
The post is for a duration of 2 years, extensible to a 3rd year (depending
on funding).
Contact
Candidates should send a resume and the names and e-mail addresses of two
references to Damien Doligez
<damien.doligez AT inria.fr>,
preferably by
March 12, 2018. Please at least let us know by this date if you are interested
in the position or if you have any further questions.
We intend to hire the research engineer by June, although the exact date is
negotiable.
- [Coq-Club] research engineer (postdoc) position at MSR-Inria Joint Centre, Stephan Merz, 03/05/2018
