- To: coq-club AT inria.fr
- Subject: [Coq-Club] Coq 8.8+beta1 is out!
- Date: Wed, 21 Mar 2018 15:26:59 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 5.mo2.mail-out.ovh.net
- Ironport-phdr: 9a23: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
Dear Coq clubbers,
The Coq development team is pleased to announce the release of the
first beta version of Coq 8.8, available at:
https://github.com/coq/coq/releases/tag/V8.8%2Bbeta1
Source, Windows and OS X packages are available.
Summary of changes:
- Kernel: fix a subject reduction failure due to allowing fixpoints on
non-recursive values (#407), by Matthieu Sozeau. Handling of evars in
the VM (#935) by Pierre-Marie Pédrot.
- Notations: many improvements on recursive notations and support for
destructuring patterns in the syntax of notations by Hugo Herbelin.
- Proof language: tacticals for profiling, timing and checking success
or failure of tactics by Jason Gross. The focusing bracket ``{``
supports single-numbered goal selectors, e.g. ``2:{``, (#6551) by Théo
Zimmermann.
- Vernacular: cleanup of definition commands (#6653) by Vincent Laporte
and more uniform handling of the ``Local`` flag (#1049), by Maxime
Dénès. Experimental ``Show Extraction`` command (#6926) by Pierre
Letouzey. Coercion now accepts ``Prop`` or ``Type`` as a source (#6480)
by Arthur Charguéraud. ``Export`` modifier for options allowing to
export the option to modules that ``Import`` and not only ``Require`` a
module (#6923), by Pierre-Marie Pédrot.
- Universes: many user-level and API level enhancements: qualified
naming and printing, variance annotations for cumulative inductive
types, more general constraints and enhancements of the minimization
heuristics, interaction with modules by Gaëtan Gilbert, Pierre-Marie
Pédrot and Matthieu Sozeau.
- Library: Decimal Numbers library (#6599) by Pierre Letouzey and
various small improvements.
- Documentation: a large community effort resulted in the migration of
the reference manual to the Sphinx documentation tool.
- Tools: experimental ``-mangle-names`` option to coqtop/coqc for
linting proof scripts (#6582), by Jasper Hugunin.
More information can be found in the CHANGES file. Feedback and bug
reports are extremely welcome.
Version 8.8 is the third release of Coq developed on a time-based
development cycle. Its development spanned 6 months from the release of
Coq 8.7 and was based on a public roadmap. The development process was
coordinated by Matthieu Sozeau. Maxime Dénès was in charge of the
release process.
The Coq Development Team
- [Coq-Club] Coq 8.8+beta1 is out!, Maxime Dénès, 03/21/2018
- Re: [Coq-Club] Coq 8.8+beta1 is out!, Maxime Dénès, 03/22/2018
