coq-club - Re: [Coq-Club] Define a function using tactics without a type
  • To: Joachim Breitner <mail AT joachim-breitner.de>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Define a function using tactics without a type
  • Date: Mon, 16 Apr 2018 18:00:50 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=ikdc AT mit.edu; spf=Pass smtp.mailfrom=ikdc AT mit.edu; spf=None smtp.helo=postmaster AT dmz-mailsec-scanner-4.mit.edu
  • Ironport-phdr: 9a23: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
On 04/16/2018 05:24 AM, Emilio Jesús Gallego Arias wrote:
Hi Joachim,
Joachim Breitner
writes:
Definition foo4. exact body. Defined.
Is there a way of doing so? I.e. a way of using tactics to define a
function without having to specify the type before?
IMHO this certainly deserves to open a feature request on github, and
shouldn't been too hard to do for 8.9.
E.
https://coq.inria.fr/distrib/current/refman/miscellaneous.html#hevea_default1159
Require Import Coq.derive.Derive.
Derive type SuchThat type As foo.
exact 3.
Defined.
