- From: Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Why must || make progress?
- Date: Tue, 17 Apr 2018 03:22:42 +0000
- Accept-language: en-CA, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=fdhzs2010 AT hotmail.com; spf=Pass smtp.mailfrom=fdhzs2010 AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM04-BN3-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi all,
From the documentation https://coq.inria.fr/refman/ltac.html#hevea_tactic222, it says that
> expr1 || expr2 is equivalent to
first [ progress expr1 | expr2 ]
While the documentation of Ltac + says following
expr1 + expr2
expr1 and expr2 are evaluated to v1 and v2 which must be tactic values. The tactic value v1 is applied to each focused goal independently and if it fails or a later tactic fails, then the proof backtracks to the current goal and v2 is applied.
which says expr1 does not have to make progress. Following program illustrates the difference:
idtac || idtac "here".
(* here *)
(idtac "here" + idtac "not here").
(* here *)
Abort.
I used to consider || to be a "more controlled" version of +, and therefore expect their behavior should be the same, modulo the backtracking part. So why || would need to have an extra requirement for making progress? If somehow it must, then why doesn't
expr2 have to make progress as well? Also why doesn't expr1 of [tryif] have to make progress? Sorry but this is a quite puzzling point.
- [Coq-Club] Why must || make progress?, Jason -Zhong Sheng- Hu, 04/17/2018
