- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Installing Coq using Opam
- Date: Wed, 18 Apr 2018 15:06:34 +1000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mukeshtiwari.iiitm AT gmail.com; spf=Pass smtp.mailfrom=mukeshtiwari.iiitm AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr0-f171.google.com
- Ironport-phdr: 9a23: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
Hi Everyone,
I am recently updated the OCaml compiler to 4.06.0 u5935541@newport:~/Mukesh/Code/EncryptionSchulze/code$ which ocaml
/home/users/u5935541/.opam/4.06.0/bin/ocaml
u5935541@newport:~/Mukesh/Code/EncryptionSchulze/code$ opam install coq
The following actions will be performed:
∗ install coq 8.7.2
=-=- Gathering sources =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
[coq] Archive in cache
=-=- Processing actions -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
[ERROR] The compilation of coq failed at "make -j4".
Processing 1/1: [coq: rm]
#=== ERROR while installing coq.8.7.2 =========================================#
# opam-version 1.2.2
# os linux
# command make -j4
# path /home/users/u5935541/.opam/4.06.0/build/coq.8.7.2
# compiler 4.06.0
# exit-code 2
# env-file /home/users/u5935541/.opam/4.06.0/build/coq.8.7.2/coq-31520-d2c37b.env
# stdout-file /home/users/u5935541/.opam/4.06.0/build/coq.8.7.2/coq-31520-d2c37b.out
# stderr-file /home/users/u5935541/.opam/4.06.0/build/coq.8.7.2/coq-31520-d2c37b.err
### stdout ###
# COQC theories/FSets/FSetWeakList.v
# COQC theories/FSets/FSetEqProperties.v
# COQC theories/FSets/FSetList.v
# COQC theories/FSets/FSetAVL.v
# COQC theories/FSets/FSetToFiniteSet.v
# COQC theories/Reals/Rfunctions.v
# COQC plugins/micromega/Lra.v
# COQC plugins/micromega/Lia.v
# COQC plugins/micromega/Lqa.v
# make[1]: Leaving directory `/home/users/u5935541/.opam/4.06.0/build/coq.8.7.2'
### stderr ###
# make[1]: *** Waiting for unfinished jobs....
# File "./plugins/micromega/Lia.v", line 20, characters 0-37:
# Error: System error: "/home/groups/software/bin/.: Permission denied"
# make[1]: *** [plugins/micromega/Lia.vo] Error 1
# File "./plugins/micromega/Lqa.v", line 20, characters 0-37:
# make[1]: *** [plugins/micromega/Lqa.vo] Error 1
# make: *** [submake] Error 2
=-=- Error report -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
The following actions failed
∗ install coq 8.7.2
No changes have been performed
I understand the reason of failure, because it is trying to install in directory, /home/groups/software/bin/, which is not owned by me(u5935541) and I don't have read, write or execute permission, but it did not happen in the past whenever I installed Coq using Opam. Could someone please tell me how can I install Coq using Opam.
I have posted all the details in gist [1].
Best regards,
Mukesh Tiwari
[1] https://gist.github.com/mukeshtiwari/475624a99931ec3c008c6bb0fe1c6f9f
Best regards,
Mukesh Tiwari
- [Coq-Club] Installing Coq using Opam, mukesh tiwari, 04/18/2018
