- To: coq-club AT inria.fr
- Subject: [Coq-Club] Coq 8.8.0 is out!
- Date: Wed, 18 Apr 2018 16:03:16 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT maximedenes.fr; spf=Pass smtp.mailfrom=mail AT maximedenes.fr; spf=None smtp.helo=postmaster AT 5.mo69.mail-out.ovh.net
- Autocrypt: addr=mail AT maximedenes.fr; prefer-encrypt=mutual; keydata= xsFNBFRYkvgBEAC0Zot4S5lKkhzYK68sSb69wVyEsugASVeWPHjVpxgFG44BLFB7Te0zWHjg jK76yCUmDdpKFdIufw5PQr+3At/8G75Y3x+dGC2rg+31fPAUJvp/AfrMloH+qd+tqxbaKjtC kymLGE01Yj8m3xaV7bN9wuYwL03+staTESJFVm3CZwNAqFgIZCG6KgBGT93ybUgbPYRrTv+n Oleags7nHdPubX6SAWbZVhuweHCwiooRBVSjzyxuhTtDuAwmeZ+ca4WE3IkOWmJmq4KbCeij HJ9B2b6qSopM19dq+iBByPu+LpBCwSA9Nr9hL1XRnoNngwf0OtJ0CNiKjKsNKlAmsCHw/o48 0IoiKP40sH+zsNFeNepbIqILPaWDvTOFvtHc9FDcH2X9NHaWx73GckMzi2z5Ty4tVoEU4Tap JlDVaKWyhvtHRwxbekgk3Vq3PcKKhcLy/xsbyknVLFw8UbFj+sYwGPrzb7j2WhpisfSct3Ii vxv2FUzM3etqM+tsJ/1Oq8u1A5lQ7lSEZmsCQdeyzMXmrUgXAEZvcx5anmTlNR3TjoG6sOxm axp9f/zgZmr9pV/FRq9tLIu8Eqv8+HqeUcHfxICcnXHVPz2x1h6H6ft45h9LGPEi1riCiZZ5 eFnq/epTkpQF411fo7sY1osaZ0Sp9yrHIPAtmJT40tmPQflSYQARAQABzSZNYXhpbWUgRMOp bsOocyA8bWF4aW1lLmRlbmVzQGlucmlhLmZyPsLBdwQTAQoAIQUCVFiS+AIbAwULCQgHAwUV CgkICwUWAgMBAAIeAQIXgAAKCRAWr2+lkXvTQPz8D/4lUpXfqOp0ZVc9WTBr8bDxHE334Bd9 FnekcYCRrmOUE76oMsK1/MhoKCEmr5bdyn8oh/r2GsNTWB1lsHpTEjYc2Sf17LNW2ncVu4OB EsD38chB9aTEev5Pc2jAA7l/WF8ceF5mkt6OjWrBfDp6yBfXwrzDfdzLixVHVyJUYA/04T7U JZc7Rjz1CdXE2wg8KL7+uq/QGc5TCPPQmlpdXJYpDgK7FtJasRoh34/pVFGHXXA1PnCe+IIL 52DynkF+bCL3sWk8A71ebUkyTO6ytqUKYafCPjrrGv4y13O+/2QcB3Iz4gDiKgvL8FWMhmhJ QF5C8BucOE87JWb5nJmq+Gs13NVofYMpmI+DDaBNJ6ns/sbR68vRfoXEhr0adPDLZOohZKJM Lu6WTjyFNNOgj1jgG0I00+tctmtW00W+U3oi36vbUXalbi5WPlIBpIXkjI9p7xoHe1mJwN40 jn/ExEXnY9uZ4H/NorJ7OzGdEOlz+ZpkcBpW34N5GZfOg7UXScA3tAFPyWcxCKsxAti0sRAR fIQXkxwt+BTBMm5m7n+wxe/2sf+xxO6AYyedWRbLaTCexJEw4Tx4+hocFT8lD6y/cGPORcak AkoWz2aiGQK07gbJ5dxymCP6g0Xcl8CloXodwV124G2++eQpucydK4BRFDTyJLJJNAR3nkei s1BBj87BTQRUWJL4ARAAqLecjPrMCx42r822nQT6e8GTHrFKwppkRqSXAucAZ4ICJ1YoT2Hy z+DtehqEV5IdIDGRivKvQYQF1Yz2NpgO7vfmB1M8ZsxyTyFeQiBkFIb5BKVhUk0xat2Xjgmb PJ59GsEbH5DCIrUqFRRGshjgul/z0adUF5DjFyuqo5TMAJdgXtJbTzmCTXoBwJmNuaUHwieK s47K9pmnnaUnkSy+CDTjtOihNeSx+lmrzieo8OyYuwvY1V1av+dJlF6YF7D5X9gHUAMsSypq pdQX0PhUZ4XheCiC0HojVzT3NEEkZ3LjuAGD7+1yaWNepGgqFqiaGEq4ihjihbvW3rCO84RS 9rSb6F7Eru7HMDUKLmUDc37GhOC0xcrTJ5zZ0CwTaM6V2P2n/FxOXEoKwRVGdAAWvh521N7k pYQpGsamfCzl8ruaEf/IhksPZiyJC95W5jXl98UDf6WNm/xKXwF60oK56iSBj+YWmUgjAzGf XRCJyiXAlMtBhErkije2iIqKVungP3N4IPEhmDOLVa9BsdXAsptkWSmWzvJA+z0A52hta0/2 B71dreoGFVnmLWWSCR+O6P9yivnfEKq75QPjBLj6xw6nXxtyhyrVT2/xOy1Osvf2mM7Gx9wR Q0Ktv7fjX2AyIrcvR3r3/RgsDA3/elqkcrY1hdu+NkOHOKtME43htXsAEQEAAcLBXwQYAQoA CQUCVFiS+AIbDAAKCRAWr2+lkXvTQNfiD/0fD2LeHa/7Vq7ClzMgjaCm5Jt2afGZi9xrD+Z8 4/wlVjFI8TZsYoiq6OTbvn6eNFE7J0wYpAouYS6GP/Ga+e/eo9Hm3BeK9+1gP0QSfwcA1+ci n+zvD5q58Movy7qo4BOoJM2eb8FpdyeloViTUlxgqocZK35ewTK0q3JcMlSZZxdOvCol3F8r CWkXqHlJoA9dL16VxBbxmT57ogqgpOFfIbc9PHMjQaNY5BWLz1+qj4bXN5UXvibP97tas1LE 4OilGPIW/ZOMItfVcxi9//huyTJt0l4lRJRochpmppItYeDs6tFyFu4XpEgUbAXwTnANqHr2 N0OSZT3j+BTMgVrs5sUgjMlqNJkMKjZmkIuSoIZbtYHfQgSY2VBPImLyWpu+XdzjBwFbuMJK 8q9tvgG2ydZCDbpC6Bi0FF+WKmZZqSkqgIFjUOkLGh624JQLbU/aezYrrhORDGEIAGtHbdn3 pC1fcAJHwI3JpRpNwou+lc8SORjUoTpSOmc5C0qWu0P7D1Y3k8gFngN/c42TX6eyyVpQw44h A6bxBs56DrE8OPyt15lveeMxT/0scd/MJlFJY/Dy+XelA0Utt0SUgSqI+TaL2eTlwNCmhNL+ ShCTVRcfb1UFlSA+GyURCLoUjrbukm7GS0pKhF+O9eCj1DkYEdi9NTjs83wKHHYu8CspWw==
- Ironport-phdr: 9a23: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
- Openpgp: preference=signencrypt
Dear Coq clubbers,
The Coq development team is pleased to announce the release of Coq
8.8.0, available at:
https://coq.inria.fr/download
Source, Windows and OS X packages are available at:
https://github.com/coq/coq/releases/tag/V8.8.0
Nix and OPAM packages are also available.
This release includes:
- Kernel: fix a subject reduction failure due to allowing fixpoints on
non-recursive values (#407), by Matthieu Sozeau. Handling of evars in
the VM (#935) by Pierre-Marie Pédrot.
- Notations: many improvements on recursive notations and support for
destructuring patterns in the syntax of notations by Hugo Herbelin.
- Proof language: tacticals for profiling, timing and checking success
or failure of tactics by Jason Gross. The focusing bracket ``{``
supports single-numbered goal selectors, e.g. ``2:{``, (#6551) by Théo
Zimmermann.
- Vernacular: cleanup of definition commands (#6653) by Vincent Laporte
and more uniform handling of the ``Local`` flag (#1049), by Maxime
Dénès. Experimental ``Show Extraction`` command (#6926) by Pierre
Letouzey. Coercion now accepts ``Prop`` or ``Type`` as a source (#6480)
by Arthur Charguéraud. ``Export`` modifier for options allowing to
export the option to modules that ``Import`` and not only ``Require`` a
module (#6923), by Pierre-Marie Pédrot.
- Universes: many user-level and API level enhancements: qualified
naming and printing, variance annotations for cumulative inductive
types, more general constraints and enhancements of the minimization
heuristics, interaction with modules by Gaëtan Gilbert, Pierre-Marie
Pédrot and Matthieu Sozeau.
- Library: Decimal Numbers library (#6599) by Pierre Letouzey and
various small improvements.
- Documentation: a large community effort resulted in the migration of
the reference manual to the Sphinx documentation tool. The new
documentation infrastructure (based on Sphinx) is by Clément
Pit-Claudel. The migration was coordinated by Maxime Dénès and Paul
Steckler, with some help of Théo Zimmermann during the final integration
phase. The 14 people who ported the manual are Calvin Beck, Heiko
Becker, Yves Bertot, Maxime Dénès, Richard Ford, Pierre Letouzey, Assia
Mahboubi, Clément Pit-Claudel, Laurence Rideau, Matthieu Sozeau, Paul
Steckler, Enrico Tassi, Laurent Théry, Nikita Zyuzin.
- Tools: experimental ``-mangle-names`` option to coqtop/coqc for
linting proof scripts (#6582), by Jasper Hugunin.
More information can be found in the CHANGES file. Feedback and bug
reports are extremely welcome.
Version 8.8 is the third release of Coq developed on a time-based
development cycle. Its development spanned 6 months from the release of
Coq 8.7 and was based on a public roadmap. The development process was
coordinated by Matthieu Sozeau. Maxime Dénès was in charge of the
release process.
The Coq Development Team
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Coq 8.8.0 is out!, Maxime Dénès, 04/18/2018
- Re: [Coq-Club] Coq 8.8.0 is out!, Perry E. Metzger, 04/27/2018
