coq-club - Re: [Coq-Club] Removing type class instances
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Removing type class instances
  • Date: Mon, 23 Apr 2018 14:52:18 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr0-f169.google.com
  • Ironport-phdr: 9a23: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
Dear Michael,
  Remove Hints effectively removes the instance from the hint database but not the other database of instances
used by Print Instances (use Print HintDb typeclass_instances to check), i.e. they are now out of sync. There should
rather be a Remove Instance command that properly removes the instance also from that database (which, AFAIR,
is only used for Print Instances actually), maybe you can submit a Coq issue about this?
Best,
-- Matthieu
On Mon, Apr 23, 2018 at 10:17 AM Soegtrop, Michael <michael.soegtrop AT intel.com> wrote:
Dear Coq Users,
I thought that type class instances can be removed with Remove Hints (although it isn’t documented this seems to be the obvious way). But it doesn’t seem to work (8.7.2):
Require Import Morphisms.
Require Import Classes.Morphisms_Prop.
Remove Hints all_iff_morphism : typeclass_instances.
Print Instances Proper.
The Print output still contains “all_iff_morphism” and it still seems to be used.
What is the proper way to remove type class instances?
Best regards,
Michael
P.S.: I want to do this primarily for demonstration purposes.
Intel Deutschland GmbH
Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
Tel: +49 89 99 8853-0, www.intel.de
Managing Directors: Christin Eisenschmid, Christian Lamprechter
Chairperson of the Supervisory Board: Nicole Lau
Registered Office: Munich
Commercial Register: Amtsgericht Muenchen HRB 186928
