- From: José Manuel Rodriguez Caballero <josephcmac AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Inductive types and isomorphisms....
- Date: Sun, 6 May 2018 17:41:26 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=josephcmac AT gmail.com; spf=Pass smtp.mailfrom=josephcmac AT gmail.com; spf=None smtp.helo=postmaster AT mail-yb0-f171.google.com
- Ironport-phdr: 9a23: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
Fred said
Suppose I define my own "natx" that is in every way equivalent to "nat" except I rename the constructors "Sx" and "Ox". It is straightforward to write coercions from natx into and out of nat and prove these form a bijection. I would like to think that I can now "import" all of the rich theory surrounding nat and make it available for my type natx.
In UniMath (the Martin-Löf part of Coq plus Univalence) you can prove that nat and natx are equal. In the "Oxford lectures on UniMath" (In particular, I recommend the Lecture 6, November 26, 2015), Voevodsky explains how to use the univalent axiom in his library "Foundations": https://www.math.ias.edu/vladimir/Lectures
The library "Foundations" is here: https://github.com/UniMath/Foundations
2018-05-06 17:01 GMT+02:00 Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>:
> I guess I need
> the equivalent of nat_rect but if the definition isn't transparent, I
> don't think you can prove anything about it.
You need to add the computation rules.
Gaëtan Gilbert
On 06/05/2018 16:24, Fred Smith wrote:
Hi,
I have thoroughly confused myself, and hope someone can help straighten me out. I started down this question trying to understand how to abstract an interface away from the actual implementation, and it occurred to me that the question is very general.
I have half-convinced myself that this is possible through writing trivial wrappers. My first question is: is there a hole? Is there something I cannot import nearly for free? I expect problems around higher-order arguments but it looks like it works out?
Still, all this work to write wrappers seems unnecessary. Conceptually the unique thing about nat is not the name "S" and "O" but its structure. Therefore, I ought to be able to write a Module Type interface hiding this detail. Then if all of the proofs about "nat" were parameterized by this interface, I could very easily get all the theory for "nat" for free for natx.
My contrived example does not seem so interesting, but suppose I found some sub-structure that was isomorphic to nat then suddenly this might be much more interesting. (I don't have an actual example, just imagining one)
Where I am stuck is writing this Module Type interface. I can't seem to come up with anything that can serve as a computational replacement for nat without effectively exporting an inductive type exactly like nat. My interface can contain nat_ind which is fine for reasoning about propositions (at least it seems fine), but I have been unable to produce any useful definition that will let me define "plus". I guess I need the equivalent of nat_rect but if the definition isn't transparent, I don't think you can prove anything about it.
Thanks for your help,
Fred
- [Coq-Club] Inductive types and isomorphisms...., Fred Smith, 05/06/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Gaëtan Gilbert, 05/06/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., José Manuel Rodriguez Caballero, 05/06/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Morrisett, 05/06/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Fred Smith, 05/07/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., James Lottes, 05/07/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Matthieu Sozeau, 05/08/2018
- RE: [Coq-Club] Inductive types and isomorphisms...., Soegtrop, Michael, 05/08/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Bas Spitters, 05/08/2018
- RE: [Coq-Club] Inductive types and isomorphisms...., Soegtrop, Michael, 05/09/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Bas Spitters, 05/09/2018
- Re: [Coq-Club] Inductive types and isomorphisms...., Théo Zimmermann, 05/09/2018
