coq-club - Re: [Coq-Club] set_timeout in 8.8.0
  • To: Gabriel Scherer <gabriel.scherer AT gmail.com>
  • Cc: Coq Club <coq-club AT inria.fr>, Burak Ekici <ekcburak AT hotmail.com>
  • Subject: Re: [Coq-Club] set_timeout in 8.8.0
  • Date: Mon, 7 May 2018 13:17:53 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lukaszczz AT gmail.com; spf=Pass smtp.mailfrom=lukaszczz AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f176.google.com
  • Ironport-phdr: 9a23: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
>> It seems generally well-known¹ that, following POSIX, "alarm" is
>> process-level
>> and may deliver the SIGALRM signal to any thread² that does not
>> explicity block it -- I don't think the OCaml runtime is supposed to
>> give any stronger guarantees than POSIX on these system calls.
Yes, from the pages you link to it seems that indeed OCaml runtime
behaves as it's supposed to here. So it seems it's a bug in Coq after
all. But there is a bug somewhere, because the timeout tactical does
not behave according to its specification.
