Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?
- Date: Mon, 14 May 2018 15:20:40 -0700 (PDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=roconnor AT theorem.ca; spf=PermError smtp.mailfrom=roconnor AT theorem.ca; spf=PermError smtp.helo=postmaster AT theorem.ca
- Ironport-phdr: 9a23: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
To follow up on this thread, I have devised a "solution" to memoizing a structurally recursive function on binary trees. However, it isn't pretty.
You can find my code MemoOrdBinTree.v @ <https://gist.github.com/roconnor/286d0f21af36c2e97e74338f10a4315b>
The construction in Coq is made more difficult (than in Agda, for example) due to Coq's positivity condition not accepting "Bushy Datatypes" (see <https://www.cs.ox.ac.uk/richard.bird/online/BirdMeertens98Nested.pdf>). I created a coinductive datatype based on Catalan's triangle for holding computed results <https://gist.github.com/roconnor/286d0f21af36c2e97e74338f10a4315b#file-memoordbintree-v-L111>. It bears some resemblance to Saizan's Agda code @ https://cstheory.stackexchange.com/a/40645 whereby the binary tree input is first preprocessed by decorating it with size information. In my case the size of a binary tree is the number of internal (non-leaf) nodes of the tree.
After counting the number of internal nodes, the lookup function reaches that far into a coinductive stream of these Catalan-shaped containers <https://gist.github.com/roconnor/286d0f21af36c2e97e74338f10a4315b#file-memoordbintree-v-L252> to pick out the appropriate container that memoizes inputs of that size. Then it will traverse that container to find the location that holds the value for the particularly shaped tree of that size.
The sharing across recursive calls happen because a let statement <https://gist.github.com/roconnor/286d0f21af36c2e97e74338f10a4315b#file-memoordbintree-v-L271> shares an inductive list of all recursive values of smaller sized trees when generating the coinductive stream all all results.
This all seems to "work". For some example tests <https://gist.github.com/roconnor/286d0f21af36c2e97e74338f10a4315b#file-memoordbintree-v-L380-L383>
Time Eval vm_compute in (memoFoldOp (fullTree 9)).
Time Eval vm_compute in (memoFoldOp (fullTree 8)).
the second call to (memoFoldOp (fullTree 9)) takes less time than the first call, while both calls to (memoFoldOp (fullTree 8)) take the same time, indicating the result for (memoFoldOp (fullTree 8)) was cached during the computation of (memoFoldOp (fullTree 9)).
Compare this to the non-recursively memoization of MemoBinTree.v @ <https://gist.github.com/roconnor/52375c3a81c927c5a8234be858f9830b#file-memobintree-v-L126-L129>
Time Eval vm_compute in memoFoldOp (fullTree 12).
Time Eval vm_compute in memoFoldOp (fullTree 11).
where the first call to (memoFoldOp (fullTree 11)) also take longer to evaluate because there is no sharing of results from the previous call to (memoFoldOp (fullTree 12)).
However, my recursive memoization solution is awful, as you may have guessed by the relative sizes of the example inputs between the recursive and non-recursive memoization functions. My recursive memoization computation and lookup has so much overhead in it that it probably isn't practically beneficial over the non-recursive memoization. The code uses function-definition-by-tactic throughout, which is never a good sign in a Coq development. I suspect there are lots of places where there is quadratic time-complexity of evaluating arithmetic equalities down to refl_equal, which need to be transparent for the elimination of eq_rect statements used to align the dependent types used. Perhaps with some care these can be reduced to linear-time complexity, but perhaps that isn't possible with this design. Perhaps the recursive and non-recursive solutions can be composed where the non-recursive solution memoizes the expensive recursive computations, while the non-recursive solution memoizes the expensive lookup of the recursive memoization.
Overall, I think my solution is much too complex to be useful, and I'm hope that there is some better way to solve this. With the non-recursive solution, the coinductive structure is simply traversed in accordance to the input tree shape, which is relatively elegant compared to my recursive solution involving computing sizes of trees and looking it up in a linearized coinductive stream of results.
The lazy Haskell solution works so well, that I'm still hoping that there is some way to capture the same operational qualities of it in a dependently typed language.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- Re: [Coq-Club] How can you build a coinductive memoization table for recursive functions over binary trees?, roconnor, 05/15/2018
