- To: Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Conditionally apply a multi-goal tactic?
- Date: Wed, 23 May 2018 17:16:34 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hamlen AT utdallas.edu; spf=Pass smtp.mailfrom=hamlen AT utdallas.edu; spf=None smtp.helo=postmaster AT esa1.hc50-71.r1.ces.cisco.com
- Ironport-phdr: 9a23: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
Hi Jason, In my case, my tactic uses "cycle" and "swap" after repeated "destruct" to reorganize the goal order. When the number of goals is large, and there is a more natural order than the one yielded by "destruct", this can be very useful. Otherwise one must manually find and focus each logically "next" goal out of a sea of perhaps hundreds of goals, which can be very tedious. However, my question also applies to any tactic that consults "numgoals" (e.g., to constrain goal explosions), even if the tactic doesn't do any goal-reordering. It's not clear to me why tactics like "||" must restrict focus to a single goal even when the tactics on which they operate are applicable to multiple goals. Best, Kevin On 5/23/2018 4:37 PM, Jason -Zhong
Sheng- Hu wrote:
Hi Kevin,
This way of constructing auto tactics makes me curious. How
do you use `cycle` in your tactic? Would the use of that be
substantially useful?
Thanks,
Jason Hu
-------- Original message --------
Date: 5/23/18 17:27 (GMT-05:00)
Subject: [Coq-Club] Conditionally apply a multi-goal
tactic?
Dear Coq Users,
I have a tactic T that operates on multiple goals as a group (e.g., it uses the "cycle" tactic). I would like to repeatedly apply this tactic until it fails or there are no more focused goals. How can I do so? I first tried the obvious: "all: repeat T." But that doesn't work because "repeat" cancels the "all" specifier, narrowing the proof scope to one goal at a time, and preventing T from operating on multiple goals. One can verify this by executing the following: Ltac showgoalcount := let g:=numgoals in idtac g. Goal True /\ True. split. all: repeat showgoalcount. (* prints two 1's instead of a 2 *) Abort. I then tried a recursive ltac: Ltac myrepeat T := let n := numgoals in (guard n=0 || (showgoalcount; T; myrepeat T)). But that doesn't work either, because "||" also cancels the "all" specifier, which one can verify by executing this: Goal True /\ True. split. all: myrepeat reflexivity. (* prints two 1's instead of a 2 then a 1 *) Qed. Similar experiments reveal that "try", "tryif", and "first" all fail for the same reason. The only partial solution I can find is the following (rather ridiculous) use of "do": Ltac crazyrepeat T := let n:=numgoals in do n (showgoalcount; T; crazyrepeat T). This actually works when T never fails, because "do n ..." has the desired effect of succeeding without doing anything when n=0, yet it keeps all goals in focus when n>0. But failures of T cause the whole tactic to fail instead of making progress; and this solution scales out of control when the number of goals is large, since it queues n recursive calls on every iteration, resulting in an exponential number of iterations. Is there any solution? Best regards, Kevin |
- [Coq-Club] Conditionally apply a multi-goal tactic?, Kevin Hamlen, 05/23/2018
- RE: [Coq-Club] Conditionally apply a multi-goal tactic?, Jason -Zhong Sheng- Hu, 05/23/2018
- Re: [Coq-Club] Conditionally apply a multi-goal tactic?, Kevin Hamlen, 05/24/2018
- Re: [Coq-Club] Conditionally apply a multi-goal tactic?, Jason -Zhong Sheng- Hu, 05/24/2018
