Re: [Coq-Club] A plugin to disable positivity check, guard check and termination check
- To: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] A plugin to disable positivity check, guard check and termination check
- Date: Thu, 21 Jun 2018 22:40:01 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tringer AT cs.washington.edu; spf=None smtp.mailfrom=tringer AT cs.washington.edu; spf=None smtp.helo=postmaster AT mail-ua0-f179.google.com
- Ironport-phdr: 9a23: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
Out of curiosity, is it documented at all which flags we could set from the plugin level that would lead to unsafe behavior? My impression is it'd be hard to do this by accident, but I still would love to know what to avoid, as a plugin developer.
On Thu, Jun 21, 2018 at 1:40 AM, Simon Boulier <simon.boulier AT inria.fr> wrote:
Dear all,
I made a plugin to experiment with type in type, non positive inductive
types and non terminating fixpoints:
https://github.com/SimonBoulier/TypingFlags
Enjoy!
Simon Boulier
- [Coq-Club] A plugin to disable positivity check, guard check and termination check, Simon Boulier, 06/21/2018
- Re: [Coq-Club] A plugin to disable positivity check, guard check and termination check, Talia Ringer, 06/22/2018
