- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is it time...
- Date: Fri, 22 Jun 2018 19:20:07 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=bcpierce AT cis.upenn.edu; spf=Pass smtp.mailfrom=bcpierce AT cis.upenn.edu; spf=None smtp.helo=postmaster AT mx0a-000c2a01.pphosted.com
- Ironport-phdr: 9a23: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
Types-Announce used to have a policy of accepting ‘marginal’ announcements
iff they included an explicit preface explaining their relevance to the types
community. Recent moderators have loosened the policy, but I still think it
was pretty good.
- Benjamin
> On Jun 22, 2018, at 18:37, Derek Dreyer
> <dreyer AT mpi-sws.org>
> wrote:
> Btw, Hugo, to answer your question about Types/announce: When I was
> moderator, we adopted a pretty lenient policy concerning
> announcements, but the announcements had to at least be something
> plausibly PL-related to be accepted. The posts that raised some
> people's hackles earlier today seemed to be about random topics with
> no relation to PL. We would have rejected those posts, but probably
> not the other posts that you mentioned in your mail.
> Nevertheless, I would argue that independent of that point, it would
> be great to see announcements on a separate list because those posts
> are of a fundamentally different nature than the technical coq-club
> posts.
> Thanks!
> Derek
>> On Sat, Jun 23, 2018 at 12:24 AM Derek Dreyer
>> wrote:
>> Hi, Hugo.
>> Given that the list is moderated, which I (and others) did not
>> realize, my suggestion would be to consider splitting the list into
>> two lists: one for actual substantial discussions concerning Coq, type
>> theory, etc., and one for announcements. The TYPES list split into
>> two such lists a long time ago, and it was a useful distinction.
>> Personally, I can say for myself that I am not particularly interested
>> in any of the announcements posted on coq-club -- and I delete them
>> immediately -- because I expect that any sufficiently interesting
>> announcement will also be sent to Types-announce. (That may or may
>> not be the case, but it is my attitude, and I imagine I'm not alone.)
>> So I would be quite happy if coq-club were split into two mailing
>> lists, the current one (reserved for actual Coq-related posts) and a
>> coq-club-announce list (for which you can apply whatever filter you
>> like because I wouldn't subscribe to it :-).
>> Best regards,
>> Derek
>>> On Sat, Jun 23, 2018 at 12:17 AM Hugo Herbelin
>>> <Hugo.Herbelin AT inria.fr>
>>> wrote:
>>> Dear Benjamin, Derek, contributors to the discussion,
>>> As indicated by Matthieu, the current discussion started from wrong
>>> assumptions. The ICPRAM/ICORES/ICAART mails which pushed Benjamin to
>>> initiate the discussion were sent by non-subscribed senders and
>>> arrived in the hands of the moderators.
>>> Altogether, there are 5 people with moderation rights, but, out of
>>> habits, two are effectively moderating. One moderator is taking in
>>> charge to systematically forward Coq related messages from
>>> unsubscribed senders (unless this is a duplicate or similar reason)
>>> and I'm dealing with the rest of the messages.
>>> In general, I'm forwarding the announcements related to our
>>> communities in a large sense (type theory, formal methods, ...),
>>> and/or with Program Committees including people from our communities,
>>> and/or which I feel may be of interest for some readers.
>>> Evaluating whether it is worth to re-send an announcement is
>>> delicate. Sometimes, not knowing what decision to take, I'm even
>>> looking at what decisions other public lists such as U-Penn's TYPES,
>>> or the lists for Isabelle, or Agda, or OCaml are taking.
>>> Maybe was I today in a favorable day. In any case, I shall accept the
>>> criticism that these 3 announcements are at the margin of the Coq
>>> topic and only loosely (potentially) connected to formal proofs. Are
>>> they spam? Are they fake? My quick evaluation was that there were not,
>>> but I may be wrong and I'd be ready to revise my judgment. After all,
>>> Coq is not exclusively used by people from our "usual" communities, so
>>> if some people from loosely connected communities evaluate (assuming
>>> good faith) that Coq is a potential valuable tool for their community,
>>> I don't see why they should be (at least systematically) excluded.
>>> Then, how to reformulate Benjamin's question based on this new
>>> information?
>>> - Is the non-moderation of the list to subscribers a problem?
>>> Moderating each message would require more man power and would
>>> induce delays in the communication. My own feeling is that the
>>> current ratio signal/noise is rather good. Even if not everyone is
>>> interested in any "philosophical" question, or in any beginner
>>> question, or in any subscriber-sent announcement already sent on 3
>>> or 4 other mailing lists, it is relatively easy to select what is of
>>> interest for each of us.
>>> - Should Coq-club stop to be about announcements not strictly related
>>> to Coq?
>>> Then announcements for the Coq workshops would be ok, but no more
>>> announcement for general conferences or workshops of our
>>> communities, no more announcements for summer schools without a
>>> class on Coq, no more job offer not explicitly mentioning Coq...
>>> After all, several of us receive such announcements in multiple
>>> copies and an extra announcement on Coq-club may not be needed to
>>> reach more people?
>>> - If non-strictly-Coq announcements are still welcome, should the
>>> policy on announcements from non-subscribers be different?
>>> For the record, in the recent weeks, announcements from
>>> non-subscribers were sent for CICM, SYNACS, MPC, iFM, ACL2, HOPE,
>>> VTSA, ... and I forwarded the mails. If we leave aside the 3
>>> contentious announcements sent today, is the moderation limit not
>>> put at the right place?
>>> Incidentally, I would be curious at knowing what policy TYPES/announce
>>> or Haskell, or Isabelle, or Agda, ... are adopting for moderating
>>> conference announcements.
>>> Best,
>>> Hugo
>>>> On Fri, Jun 22, 2018 at 10:03:50PM +0200, Matthieu Sozeau wrote:
>>>> Actually, posts are moderated! We just ought to be stricter on
>>>> announcements.
>>>> Le ven. 22 juin 2018 à 20:28, Derek Dreyer
>>>> a écrit :
>>>> I thought of it, but didn't imagine the mailing list management would
>>>> support such a feature easily. If it does, then sure.
>>>> Derek
>>>> On Fri, Jun 22, 2018 at 8:26 PM Clément Pit-Claudel
>>>> <cpitclaudel AT gmail.com>
>>>> wrote:
>>>>>> On 2018-06-22 14:18, Derek Dreyer wrote:
>>>>>> Another idea would be to not moderate posts but have a stronger
>>>>>> vetting process for determining who has the right to post rather than
>>>>>> just allowing anyone. However, this might have the effect of
>>>>>> discouraging newbies with real Coq questions.
>>>>> Many online forums moderate the first few posts of each new user. Could
>>>> this work on coq-club?
>>>>> Clément.
- Re: [Coq-Club] Is it time..., (continued)
- Re: [Coq-Club] Is it time..., Théo Zimmermann, 06/22/2018
- Re: [Coq-Club] Is it time..., Jim Fehrle, 06/22/2018
- Re: [Coq-Club] Is it time..., Derek Dreyer, 06/22/2018
- Re: [Coq-Club] Is it time..., Pierre Vial, 06/22/2018
- Re: [Coq-Club] Is it time..., Clément Pit-Claudel, 06/22/2018
- Re: [Coq-Club] Is it time..., Matthieu Sozeau, 06/22/2018
- Re: [Coq-Club] Is it time..., Hugo Herbelin, 06/23/2018
- Re: [Coq-Club] Is it time..., Derek Dreyer, 06/23/2018
- Re: [Coq-Club] Is it time..., Benjamin Pierce, 06/23/2018
- Re: [Coq-Club] Is it time..., Benjamin C. Pierce, 06/23/2018
- Re: [Coq-Club] Is it time..., Hugo Herbelin, 06/30/2018
- Re: [Coq-Club] Is it time..., Gabriel Scherer, 06/30/2018
- Re: [Coq-Club] Is it time..., Jim Fehrle, 06/30/2018
