Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?
- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?
- Date: Thu, 28 Jun 2018 10:47:47 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay9-d.mail.gandi.net
- Ironport-phdr: 9a23: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
You can do "unshelve instantiate (1 := _)" to get the evar in your goal list, or "instantiate (1 := ?[foo])" to give it a name.
Maybe we could extend the toplevel selector to be able to take names, then you could do "[n]: { tac. tac'. ... }" (after giving it a name).
Gaëtan Gilbert
On 28/06/2018 09:41, Yannick Forster wrote:
Hi all,
Ralf's example works using inline ltac:
Goal exists (n : nat), n = 2.
eexists.
instantiate (1 := ltac:(refine (S _))).
This produces:
S ?Goal0 = 2
Does this enable your idea again Ralf?
Best
Yannick
On 28/06/18 07:37, Ralf Jung wrote:
Hi John,
I was going to suggest something like
eexists.
instantiate (1 := refine (S _)).
because "instantiate" can actually run tactics. However, the above does not
work, saying
Instance is not well-typed in the environment of ?n.
I am not sure how to get around that. It's certainly possible to refine an evar
using new evars, just not this way I guess...
Kind regards,
Ralf
On 27.06.2018 21:58, John Grosen wrote:
I am currently dealing with a problem in which I have an existential
variable in the goal and want to apply a lemma to the goal, but Coq's
unifier is not powerful enough to automatically unify the relevant part
of the lemma with the evar. However, in this particular case, it is
programatically obvious how to unify them, so I would like to write some
Ltac to do so. Imagine this (greatly simplified) example:
evar (n : nat).
exists n.
only [n]: refine (S _).
This works, but I usually don't have a name for the existential
variables I'm dealing with and the automation certainly doesn't know
about any. So what I'd like to do is this:
eexists.
match goal with
| [ |- ?x = _ ] =>
only [x]: refine (S _)
end.
However, Coq complains with "No such goal." As far as I can tell, this
is because the argument in "only [_]" is a syntactic identifier.
Then, is there any way to select a goal with a non-syntactic identifier,
like I have in this situation?
Thanks,
John
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, (continued)
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Jason -Zhong Sheng- Hu, 06/27/2018
- RE: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, John M Grosen, 06/27/2018
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Ralf Jung, 06/28/2018
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Yannick Forster, 06/28/2018
- RE: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Soegtrop, Michael, 06/28/2018
- RE: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, John M Grosen, 06/29/2018
- RE: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Soegtrop, Michael, 06/30/2018
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Armaël Guéneau, 06/30/2018
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Gaëtan Gilbert, 06/28/2018
- Re: [Coq-Club] Is it possible to perform tactics in an existential's context from Ltac?, Robbert Krebbers, 06/28/2018
