- To: coq-club AT inria.fr
- Subject: [Coq-Club] Positions at a startup company, using Coq to prove hardware
- Date: Mon, 6 Aug 2018 15:37:57 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=adamc AT csail.mit.edu; spf=Pass smtp.mailfrom=adamc AT csail.mit.edu; spf=None smtp.helo=postmaster AT outgoing-stata.csail.mit.edu
- Ironport-phdr: 9a23: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
I'm excited to announce opportunities for Coq hackers at the startup company SiFive, for which I am a technical advisor. Briefly, SiFive offers a platform to help their customers create
new hardware solutions, combining off-the-shelf components like
CPUs with application-specific components. They are very
interested in assurance about the correctness of such
integration. Their library of standard components is centered on
the very cool open instruction set RISC-V, which was created by the
founders of the company. They are located in Silicon Valley
(California, USA). SiFive is currently looking to hire a few Coq engineers to prove correctness of processors and other crucial pieces of digital hardware. I believe all or most of these components will be open-source. The verification is being done using the Coq library Kami that began its life in my group at MIT, partly under the umbrella of the DeepSpec project. My former postdoc Murali Vijayaraghavan took a job at SiFive to lead this effort. I would encourage anyone interested in learning more to e-mail
Murali. Please be aware that these positions are only open
to people with nontrivial Coq experience, though experience with
hardware engineering is not required. (It all turns out
to be functional programming, anyway!) In applying, please start
by summarizing your experience using Coq, ideally to demonstrate
correctness of (semi-)realistic systems. The approximate bar is
Coq familiarity at the level we'd expect from doing a related
master's thesis. However, there are also internship opportunities
that may be open to people with slightly less Coq experience. |
- [Coq-Club] Positions at a startup company, using Coq to prove hardware, Adam Chlipala, 08/06/2018
- Re: [Coq-Club] Positions at a startup company, using Coq to prove hardware, Murali Vijayaraghavan, 08/17/2018
