[Coq-Club] Coq code/theory manipulation tool (abstract syntax tree manipulation tool) - heurisitc transformation instead of rigorous rewriting
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Coq code/theory manipulation tool (abstract syntax tree manipulation tool) - heurisitc transformation instead of rigorous rewriting
- Date: Fri, 24 Aug 2018 20:53:43 +0000
- Accept-language: lv-LV, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=alex153 AT outlook.lv; spf=Pass smtp.mailfrom=alex153 AT outlook.lv; spf=Pass smtp.helo=postmaster AT EUR03-VE1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:s6vSBhWuGVL1MWq5gymOISH7ZnLV8LGtZVwlr6E/grcLSJyIuqrYYxyEt8tkgFKBZ4jH8fUM07OQ7/i/HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba9wIRmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W/XlMJ+kb5brhyiqRNjzIHZe5uaOOZicq7HYd8WWXRNU8BMXCJBGIO8aI4PAvIdMOZcsYb8qEYFoxygCgisGuzv0CJDi3js0q0+zesgHhzK0QwuEt8Vt3TUscn1NKMVUeCyz6nE1zHDb+1P1Dr79YPGcQghrOmDUL5sa8bczVcjGxnHg1mOs4DpITGY2vwDs2eF7OdsSeeihmslpg1svjSixMIhh4nTiY8az13L6Dt2z5spKdC9SUN2b8KoHZtWuiqHLYV5WNkiTHttuCsiyr0Jp5q7fC8SxZooyRHRd+CLfoaR7h3sW+idPC50hHV+d72hnRqy9lWgyvHnWcmzzVZKqDdKnsPUtnAX0BzT9taIRedh/keg3jaP0Rrf6uZZIUAokarbLJkhwr0qmpUPtkTDGzf6mETwjKCIakUp4uel5/j9brjiuJOQLY15hh/kPqgwmMGzGeE4PRIPX2if9+S8zrrj/UjhTbpQiv05jKbYvI3aKMkVvaO5BBJV0pon6xa4CDem084UnX0ZLF5dYhKIk5DpO03SIPD/Ffqwn1OskC5yy//aOr3hH47CI2PYkLbheLZ981RTxBAyzdBZ/ZJUC6sOLOj9Wk/r55TkCUpzOAuthu3jFd9V14UEWGvJDLXTePfZtkbN7eYyKcGNYpUUsXDzMa52yeTpiCoQnVINNYykzJYNICSxGvl2ehjCSX3xntMGFmRMuhRoH7+is0GLTTMGPyX6ZKk7/DxuUNv3X7eGfZikhfm65An+G5RXYm5cDVXVSyXvapmAXPAPLiaMcJY4zm40EIO5Qopk7imA8RfgwuM9fO3J5ikfspGl0MYnv7SOxyF3ziR9CoGm60/IT2xwmT9XFRIL5vgk5HJQkxKE26U+hOFEH9tO4f8PSh09KZPX0+19DZb1Rx7FedCKDl2hR4f/DA==
Hello!
Is there tool for Coq code/theory manipulation. Maybe there is more or less universl third party tool, that takes Coq BNF grammar as input and that generates AST manipulation tool. Or maybe Coq suite itself has such facility, of course, Coq parses code and
have some inner representation of the code.
At the first glance one can say that such code transformation is against all the idea of formally proven reasoning. But I am trying to use Coq for natural language semantics and here rigorous reasoning (e.g. logical thinking) mixes with the probabilistic/heurisitic
reasoning (e.g. what logical function to use for approximation of the semantics of some word or phrase). So - it is quite rational to do some transformation of Coq code using tools that are not formally verified and that do not give guarantees and then do
some logical reasoning using logic that is mechanized in Coq. Striving for the best that can be achieved.
Alex
- [Coq-Club] Coq code/theory manipulation tool (abstract syntax tree manipulation tool) - heurisitc transformation instead of rigorous rewriting, Alex Meyer, 08/24/2018
