- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Anybody uses the Quote plugin?
- Date: Thu, 30 Aug 2018 12:12:09 +0200
- Autocrypt: addr=Assia.Mahboubi AT inria.fr; prefer-encrypt=mutual; keydata= xsFNBFRwdNcBEACayG+RJjOUz7A9KI4UJZQ4rF53F/QbuWsVwxs+HnFaMHlGA+dyL41hOe14 B+4w50e2jHy6KaBKLP4HFVZpJKpWQsxRmP6vREpbHziF1aNNgoQAER1iriqOiNNTZG8Nbvre ve4BwVHBmbblDvqfXvHdBh35KG//kwYCwAz2g05FWNKe7OZhrQ0wjsdh9p9rSm9mSgL4jFIH 7FxpFw3I20jr+qlTXUyFHLXVjFZnxhznOGa8Kwp3o+UfkjRNUd8bBEbz+jtz1XHTbmDbQRrt msUNozyryiu2mWMt26fJZbSrk6fR/IV/y0XoTe6Uz0o2GtnjeXmCFxe7DwZtwVrina90+MuY okXmKVmv0JVlP3ic1m+GDdF0RNTh0r9w666YUmhebjgwR/3I7uc2JLHJCM9LulnQWx6aVJhH WsELeu5hLXgf9judAtZxUc8aZx7l8I4C2UDRbdSBqQTW1zhxdb6B0TCCuiNUqCISXG6xKAqm 9PsU6Ohb7rIal/yDmy4or/IclxRXx9W8WOxJxTZZt43GyK/1hS43UP6fI//V5cVAOilzOLlc iCdWtlHL4xv+gboSAAH7W1GoZyhpGKb0L3U/BhO8tkTtSPQx9d/GflmHxNBiQeccVAtEYIy4 knIrCuetxksGyZ72E9fXE62tJhwoxlCg6JvOEZAEXzHxbVfywwARAQABzShBc3NpYSBNYWhi b3ViaSA8QXNzaWEuTWFoYm91YmlAaW5yaWEuZnI+wsF+BBMBAgAoBQJUcHTXAhsjBQkJZgGA BgsJCAcDAgYVCAIJCgsEFgIDAQIeAQIXgAAKCRBWO2266JVxsV95D/0bWtsjZ1vjuZYkqR0r WVIs2/G7yYMZ24TGO3EAe/VjXkLlIwyQnUTzN29q40m195zJml99BVVrwsZD4gbV+fu2TdTC YKhgRx05IjeGvcwiOYSplrGUHWg2WN+ofBaHPLeugCmKGBIXCpKXoWS79+amIRsaemVyJB9J P6pvrHfjKXtWaL4JRlhycWv+AeuxA9YVbD/lHFdd8uG/uizIXhuammFov39XKQMujrbejNS3 GggU0XE2vsVQa1ERjgjfk64XMxn1wiXQV9KFSbcSHzSiV8i8he/Ho+xEr/ATnS5cOuK8foUf dQS8yoGQwThHMuV+yuG2d1GSnBW9qTR1x7qNf6DAEQYw7XYYfeggB50Rxe7MS2bf8sj5q/4N tB7AyJT1hcdK+v+Pjr2AjVpX6kwLdLSauLcBpp36qYhpidygQDLV3U2+IbjTrEejgHxuOs6r 1iWtMNppoezyP7IbK0wOZ+RwGE1R01blj8geOm/d5QXoRr7SHocnPyq8Jbi15g5JxTZAFuHS UxaW8k+dGsH0wQxuEcF5JTmM+2kv95Wf6W/jueU2oPt3jQnNWtYu+368scJX882tEJTfkhev 7NbXvsWFpTeK9sqftMW/1dSOkcKpHySECmTQVst8jIMLdIPLuRECBGrrzz9Gx+Pwv/MwVDLR lXOoPSK1pmx86bT47M7BTQRUcHTXARAArjgoFHzZMjM6X7AxO4aTMk+feBC5sFokah2TYdXM eDCR4SbUwNDTgBMi7JtKaUgFW4jh1Hj9NiJJHimejixiho+ZIBJdAwz+auJZVX4RL0a9gSxz hCBT6XRNckUjCJyH17ebzGlPQwgeolOJky063nVOkFmcCLInnh0Q0zbEeZ0RzwPlvNMw/F/4 WOhMQwlifIpIG/jREqcCQzNcddCsZSt9FNIGx0vlGEn5B5lvkM02fbN35/BOf/gKDYbjjgjH HJvYyKnNRHyzL6WNzJw+dKtfr1SvZ5Ms5YeY/CXm3/Xxq53MnoT0HGpjoij3o53toTdnV09z euYWlURq5mzcncSQsD+R7hlv5f2gfmDwLYQeDIwljmjVNXHnYaYtWNghiMdR5sIJvKBqB8tu 25WZd9AaqysnNEokuQi6tfbix5Am4W9J2K7CWzNT7c5n/sBbS5OJsGOW66hck7VAhHVsFjxz Wmmy2C2pIx5w3iJzrzGJlI+anaK/XxJowM5td2faiNZ5wWfVj5lkCJeEqRyAT3INz+5zPsin yQ1vU44JU6C4kjsYBhQ+2YnorrWp2ceRqg483gPYdB/d1DPjOt8j4pIqh2vbhkIo+V56owdt /yerQY1Ykn7zLJ3k/jstdXDF7fXQyFrPMpDnvzG0Gyd79jKNW6M+Hf+1wn2Y/j4YDyMAEQEA AcLBZQQYAQIADwUCVHB01wIbDAUJCWYBgAAKCRBWO2266JVxsWnED/sHj5v9vOCvf3jvzqfz qOrBIuku8M6sRPZcZWtfsXote6l8G3cso6qpNzf7LJmEqfBe4kOMwglgs0Q3osYAr7i6Fjid Qbfbx973gorst7tVek7t7i/s+HOsqW29qocNCa0uysinWjlruC/GaLbCWpcRFPWIcMyc9pCR GiHxUhqVIutwD2K0uTIjQDZzISKkZG+hsUedvlm4tS3gmRNWjg4G2xISgyJ0/AAzkP8O7riY jWZ7B1ih0WkKccBYq5BHs/JkKYuIfYww2DxlFuVbWxyi6yLulu3w4J9gNOBzRzBm2S3hggAX FUq1QHdMrTECoSQ/KioDUgcBJ1mqM53r8AgoTUBdKU8OEriGeusNvmOBA++SjQibdQTaNsqS A6m1uCcyIhvmcGHIecS80z5BftC9hEfzGTVepBwF71Qdj1UyrNkouVdRn2tlFsTF72RgMdfl Q4C15ux51RmUL9hGDYoDHFXS2TxV+0keqRsUBN7WKY7ZscTVzoeeLekr98foMXL6cECPCzQ6 d4rv+2mL8653OOcpm3KkZQy7fnmdoqo97RIzOaVo56RvI97zu7w2to4bERdRphZwwMJDv8KE AJq/P7Wp/STs2XD6wnPjGLLFikTvE/ujE5NSS5KVM3M9TdfdYO5gOQ2itiT3DU7J5Wionw4A jk5NNWijOhe6shDkUQ==
- Openpgp: preference=signencrypt
Hi,
Le 31/07/2018 à 14:43, Christian Doczkal a écrit :
> Indeed, teaching is one reason why it might be good if Coq where to ship
> with some easy to use reflection mechanism supporting, like quote does,
> simple data types and foreign subterms.
When I am teaching reflection, I usually show (and ask in related exercises) a
small Ltac function performing the reification phase. I think it is helpful to
see the pattern matching at work, and possibly also the construction of the
varmap, as opposed to having a "black box" command like Quote. Plus on a
simple
toy example, it is really not that difficult to implement.
> So keeping quote and developing it to the point where the reflective
> tactics shipped with Coq (can) make use of it, might be worthwhile.
When implementing the ring tactic a while ago, we briefly considered using it,
but eventually fall back to some specific OCaml code. I do not remember the
details.
I wholeheartedly agree that the lack of code sharing among Coq reflexive
tactics
is very unfortunate. Performance and customization are a delicate issue
though.
On the other hand, I do not know what is the best candidate for the purpose
of a
"generic and efficient refication toolkit". Maybe not the Quote plugin I
would say.
If I understand correctly the survey by Jason and his co-authors, the
pattern-based technique they propose does not deal with variable maps. Thus it
cannot be used for reflective tactics à la ring.
And therefore the problem of constructing a variable map is out of the scope
of
their benchamrk.
Some of the meta programming solution they benchmark can be used in this case
(canonical structures, type classes, etc.) and could in principle be used for
this purpose. But performance is an issue on large terms, in particular in the
variable map building phase.
> The, closely related, question that got me interested in this is: What
> is currently the simplest way to do reification into ones own
> inductively defined data type (with variables) in such a way that the
> variable map containing the foreign subterms is injective not just with
> respect to syntactic equality but with respect to conversion.
I am also interested, and I do not know the answer.
For instance, this would help interfacing automation tactics with a
canonical-structure based hierarchy of structures. But again, building a
variable map up to conversion too naively can trigger massive performance
problems. A while ago, we ran into this nature of problems when trying to
prove
identities on rational numbers represented as a pair of unary integers with a
proof. The solution involves using an opaque cast as a head symbol on
constant,
and a specific tactic parameter to deal with the leaves of a given expression.
Best,
assia
> Best,
> Christian
> On 22/07/18 11:35, Hugo Herbelin wrote:
>> Hi,
>> Somehow, a question is also whether it would be worth that someone
>> eventually provides a generic-enough quote function in Coq, for use at
>> both the vernac level or the plugin level.
>> My understanding of the Gross-Erbsen-Chlipala ITP 2018
>> reification-by-parametricity paper is that this quote function almost
>> already exists, it is "pattern". Then, what about going in the
>> direction of providing a variant of "pattern" which encapsulates the
>> boilerplate of the technique and which, maybe, also abstracts over the
>> foreign subterms?
>> Idem at the plugin level. Already e.g. ring, micromega, btauto have
>> their own reification mechanisms (sometimes even in Ltac) and this
>> seems suboptimal.
>> Best,
>> Hugo
>> On Fri, Jul 20, 2018 at 11:45:32AM -0700, John Wiegley wrote:
>>> I would also support dropping Quote; each time I've been able to use it, I
>>> ended up just copying Ltac macros from existing templates so I would have
>>> the
>>> configurability needed for future changes.
>> On Fri, Jul 20, 2018 at 08:41:28AM -0400, Tej Chajed wrote:
>>> I definitely support getting rid of Quote. I used it once and then ran
>>> into an
>>> issue: my unquote function took a type parameter, which is unsupported,
>>> even if
>>> you try specializing it. I talked to Jason Gross, copied some code from
>>> their
>>> reification-by-parametricity paper, and got it working fairly easily in
>>> pure
>>> Ltac.
>>> It would be great to have some examples from that paper coped into the
>>> Coq test
>>> suite and try to give it visibility, instead of maintaining Quote. It's a
>>> more
>>> powerful technique and I believe with just a little boilerplate can
>>> replace
>>> uses of Quote (if anybody actually weighs in and is using it).
>>> On Fri, Jul 20, 2018 at 3:20 AM Maxime Dénès
>>> <mail AT maximedenes.fr>
>>> wrote:
>>> Dear Coq-clubbers,
>>> I'm trying to clean up the set of plugins shipped with Coq, so that we
>>> can make the maintenance done by the development team more focused and
>>> effective.
>>> I was wondering if anybody was using the Quote plugin in real-world
>>> developments. See https://github.com/coq/coq/pull/7894 for more
>>> context.
>>> Thank you in advance for your feedback!
>>> Maxime.
- Re: [Coq-Club] Anybody uses the Quote plugin?, Assia Mahboubi, 08/30/2018
