coq-club - Re: [Coq-Club] 计算鸡在 [ALGTOP-L] Final announcement, Vladimir Voevodsky Memorial Conference
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] 计算鸡在 [ALGTOP-L] Final announcement, Vladimir Voevodsky Memorial Conference
  • Date: Tue, 4 Sep 2018 20:18:04 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=yishuai AT cis.upenn.edu; spf=Pass smtp.mailfrom=yishuai AT seas.upenn.edu; spf=None smtp.helo=postmaster AT mail-it0-f42.google.com
  • Ironport-phdr: 9a23:CIjaKhElG+t0RESqVYVzhJ1GYnF86YWxBRYc798ds5kLTJ7zpcywAkXT6L1XgUPTWs2DsrQY07WQ6/iocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbAhEmDiwbaluIBmqsA7cqtQYjYx+J6gr1xDHuGFIe+NYxWNpIVKcgRPx7dqu8ZBg7ipdpesv+9ZPXqvmcas4S6dYDCk9PGAu+MLrrxjDQhCR6XYaT24bjwBHAwnB7BH9Q5fxri73vfdz1SWGIcH7S60/VDK/5KlpVRDokj8KODE38G7VisJ+gqFVrg+/qRNj2IPbep2ZOeBkc6/BYd8XR2xMVdtRWSxbBYO8apMCAOgAPeZDr4n9ukEBrRqjDgeqBePk1zhFh3/33a0h0+QhDBvJ3A07Et0SsXTUt8/5NLoKUe+ryqnIyy/PYO1L1jfg8YXFdA0qr/+LXbJ1a8XRyE8vGhvFj1WXtIzlPC6V2v4RvGic6upsTfqvhHQnqgFpuDevwt0giozXiY4NxVDE9Dl5wIIvKtKjUkJ0fdmkEJ5IuyGVNot2Xt0tTH9ytCkmzb0GvJi2dzUJxpQ/3xPTdeCLfoyS7h/gVOudOyl0iG9qdb6liBu+71CsxvPgWsSwylpHrSpInsPSunwQ2BHf8MiKRuZ780y8wziAzRrT5ftBIU0slarUNZohwrkom5oWq0vDHyv2lFz3jK+Kakko4+ao5uv5brn8qZ+cMIh0ig76MqswgMCwHeM4Mg0WU2ia/+SzyqHj8FXnTLlWivA6iKrUvZDAKcgFu6K0DBVZ34k95xqnCjepytUYnX0JLFJffxKHipDkOlHPIPDjDfe/nk6jkDZwyvDdILLuGI7NImLekLf5Y7l97UhcxBAtwt9C+pJYEqsBL+7rWk/tqNzYCQc0PBCzw+b+EdlyyoceWX+UDaKCK6PTsVqI5vo1LOWWZY8Vviz9K/k/6PL0g385gwxVQa781pwOLXu8A/5OIkODYHOqjM1SP30Nu18PTffqlVSDGRpSLyKjXrk8+zg6IImnFsHeXo2rhvqM0DrtTc4eXXxPFl3ZSSSgTI6DQfpZMHvDcP8kqSQNUP2ac6Fk0BivsAHgzL8+cLjP9yQD84/72d5zoeDfiENrrGAmP4Gmy2iIClpMsCYQXTZvgfJ0oFc710+O164+jvBFR4QKuqF5FzwiPJuZ9NRUTtD/XgWbI4WMQVeiB9S6WXQ/Eoh3zNgJbEJwXd6li0Kb0g==
My filter says this email is a spam. Could someone instruct me what this user is trying to announce or discuss? Or, has 1337777.OOO AT gmail.com sent any email of Coq-Club's interest?
1337777.OOO <1337777.ooo AT gmail.com> 于2018年9月3日周一 下午7:44写道:
I QUIT MATHEMATICS ... I am the most mathematician-by-definition of
the 21st century until now .
Proph
https://gitee.com/OOO1337777/cartier/blob/master/cartierSolution8.v
https://gitlab.com/1337777/cartier/blob/master/cartierSolution8.v.pdf
solves half of some question of CARTIER which is how to program
grammatical polymorph « modos » /
modified-colimits-into-viewed-functors ( "sheafification" , "forcing"
ERRATA :: this also solves cartierSolution7.v where the
default-colimiting was "confused" .
SHORT ::
  The ends is to start with some given viewing-data on some
generator-morphology and then to modify the default-colimiting which
says that « each functor is the sum/colimit of its elements ; which is
that the (outer) indexings/cocones of the elements of some target
functor over all the elements of some source functor correspond with
the (inner) transformations from this source functor into this target
functor » . In other words : any outer indexing ( X ; (s : S X) |- T X
) corresponds with some inner transformation (   |- (S ~> T) ) . But
where are those modified-colimits ? Oneself could get them as
metafunctors over this generator-morphology , as long as oneself
grammatically-distinguishes whatever-is-interesting .
  The modified-colimiting presents this « copairing » even when any
such indexing ( « real polymorph-cocones » ) is over only some
viewing-elements of this source « viewing-functor » ( "local
epimorphism" ) , as long as the corresponding transformation is into
the (tautologically extended) « viewed-functor » ( "sheafification")
of this target functor . Memo that when the target functor is already
viewed-functor ( "sheaf" ) then this modified-colimiting becomes the
default-colimiting ; in other words it is valid to move from-to :
#+BEGIN_EXAMPLE
(f : F) ; (v : viewing at f) |- (w : viewing indexing the
                                       inner cocone (e_ f v)) -> (e_ f v w : E)
#+END_EXAMPLE
#+BEGIN_EXAMPLE
(f : F) ; ((v : viewing at f) , (w : viewing indexing the
                                       inner cocone (e_ f v))) |- (e_ f v w : E)
#+END_EXAMPLE
  « MODOS » (modified-colimitS) is the alpha-omega of polymorph
mathematics . It shows the interdependence of computational-logic
along geometry : sensible "soundness" lemma , cut-elimination ,
confluence lemma , sense-completeness lemma ( in presheaves whose
combinatorics mimick "links"/"proof-net" ) , maximality lemma ,
asymptotics of randomness , DOSEN book ... ; generated-functors (
"Diaconescu lemma" ) , equalizer completion ,  image ( "regular" )
completion , essential geometric-morphisms ( "Cauchy completion" ) ,
BORCEUX book 1-2-3 ...
  For instant first impression , the conversion-relation constructor
which says that the polyelement (injection) morphism laxly-cancels the
polytransf (copairing) morphism , is written as :
#+BEGIN_EXAMPLE
| PolyTransf_PolyElement : (* ... *)
 forall G f H (v : 'Generator( H ~> G | (V_ G f) )),
 ( (ee_(G)(f)(H)(v)) o>CoMod 'UnitViewedFunctor )
   <~~ ( ( 'PolyElement F v
           : 'CoMod( View H ~> ViewingFunctor F V_ @ _ ) )
         o>CoMod ( [[ ee_ @ F, V_data , V_transp, Yoneda10_ee_natural,
                            Yoneda10_ee_morphism, Yoneda10_ee_real ]]
                   : 'CoMod( _ ~> ViewedFunctor (ViewingFunctor E U_) @ _ ) ) )
#+END_EXAMPLE
KEYWORDS :: 1337777.OOO ; COQ ; MODOS
OUTLINE ::
  * Indexer metalogic , viewing data
    + Indexer metalogic
    + Viewing data
    + Unit (total) viewing
    + Intersection (point) viewing
    + Inner (dependent sum) viewing
  * Grammatical presentation of objects
    + Sense-decodings of the objects
    + Grammar of the objects , which carry the sense-decodings
  * Grammatical presentation of morphisms
    + Sense-decodings of the morphisms
    + Modified colimiting is default (common) colimiting when into
viewed-functors
    + Grammar of the morphisms , which carry the sense-decodings
  * Grammatical conversions of morphisms , which infer the same sense-decoding
    + Grammatical conversions of morphisms
    + Same sense-decoding for convertible morphisms
    + Cardinality of the viewing-elements of some viewing-functor
    + Linear total/asymptotic grade and the degradation lemma
  * Solution morphisms
    + Solution morphisms without polymorphism
    + Destruction of morphisms with inner-instantiation of object-indexes
  * Polymorphism/cut-elimination by
computational/total/asymptotic/reduction/(multi-step) resolution
HINT :: secondary-school engineering : redo the
generated-functor-along-reindexing cartierSolution7.v as some
modified-colimitS ( "Diaconescu lemma" ) :
#+BEGIN_EXAMPLE
| PolyTransfGenerated_ : ( forall (I : obIndexer), forall (G : obGenerator)
 (R : obReIndexer) (gr : 'Generator( G ~> Generating0 R ))
 (R_viewing : obViewingReIndexer R)
 (ri : 'Indexer( ReIndexing0 R |- ViewedIndex I )),
 forall R' (v : 'ReIndexer( R' |- R | R_viewing )),
  'CoMod( View_Generating0 R' ~> E_ (ViewedIndex I) @ Yoneda10_ee_ gr
ri v ) ) ->
'CoMod_indexed( Generated_ ~> ViewedFunctor_indexed E_ @ _ )
#+END_EXAMPLE
MEMO :: 1337777.OOO ends to discover-engineer-and-teach 计算鸡-COQ
polymorph mathematics to billions of secondary-school persons (
https://v.youku.com/v_show/id_XMzgwNzY2MTYxNg ) ; « MODOS »
(modified-colimitS) is the alpha-omega of polymorph mathematics contra
« NOISEA » (forced-fool-and-theft/lie/falsification) ...
BUY MOM RECURSIVE T-SQUARE :: paypal.me/1337777 1337777.OOO AT gmail.com
; 微信支付 2796386464 AT qq.com ; irc #OOO1337777
