- From: Frédéric Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Using Ssreflect in Coq
- Date: Wed, 5 Sep 2018 10:23:55 +0200
Thank you Théo. Perhaps it would be good to add this in the doc.
Best, Frédéric. Le 05/09/2018 à 10:21, Théo Zimmermann
a écrit :
Hello,
"From
Coq
Require
Import
ssreflect."
is a one-line command to use SSReflect. The rest are just
recommendations of the SSReflect authors that you are
perfectly allowed to ignore.
You may also install the (still existing) coq-ssreflect
package and do "From mathcomp Require Import ssreflect." in
which case it will change these options for you (but also a
few others).
Théo
Le mer. 5 sept. 2018 à 10:17, Frédéric Blanqui
<frederic.blanqui AT inria.fr> a
écrit :
Hello. In https://coq.inria.fr/distrib/current/refman/proof-engine/ssreflect-proof-language.html?highlight=ssreflect#usage, it is written: "All in all, this corresponds to working in the following context:
Is this all we have to write before using Ssreflect? Isn't there a one-line command? Frédéric.
- [Coq-Club] Using Ssreflect in Coq, Frédéric Blanqui, 09/05/2018
- Re: [Coq-Club] Using Ssreflect in Coq, Théo Zimmermann, 09/05/2018
- Re: [Coq-Club] Using Ssreflect in Coq, Frédéric Blanqui, 09/05/2018
- Re: [Coq-Club] Using Ssreflect in Coq, Enrico Tassi, 09/05/2018
