coq-club - Re: [Coq-Club] Debugging Universe Inconsistencies
  • From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Debugging Universe Inconsistencies
  • Date: Thu, 6 Sep 2018 12:55:39 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay4-d.mail.gandi.net
  • Ironport-phdr: 9a23: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
Definition T1 := Type.
Definition T2 := Type.
Definition T3 := Type.
Definition T1_le_T2 : T1 -> T2 := fun x => x.
Definition T2_le_T3 : T2 -> T3 := fun x => x.
Fail Definition T3_lt_T1 : T1 := T3.
(* The term "T3" has type "Type" while it is expected to have type "T1" (universe inconsistency). *)
Set Printing Universes.
(* The term "T3" has type "Type@{Top.3+1}" while it is expected to have type
"T1" (universe inconsistency: Cannot enforce Top.3 < Top.1 because Top.1 <= Top.2 <= Top.3).
Linking constraints to specific definitions is currently not something Coq helps you with.
Gaëtan Gilbert
On 06/09/2018 11:18, Christian Doczkal wrote:
Hello,
I already had used "Set Printing Universes". As far as I can tell, the
only thing "Set Printing Universes" does is cause "Print/Check term." to
print the universe levels of all occurrences of "Type" occurring in a
particular definition as well as the constraints enforced by a
particular definition.
I have a constraint system with thousands of constraints arising from
hundreds of definitions and I would like to know which constraints
contribute to the inconsistency and which definitions/lemmas give rise
to a given constraint.
For instance, Print Universes might mention
"Coq.Relations.Relation_Definitions.1" which I could correctly guess is
the first argument of "relation":
relation =
fun A : Type@{Coq.Relations.Relation_Definitions.1} => A -> A -> Prop
: Type@{Coq.Relations.Relation_Definitions.1} ->
Type@{max(Coq.Relations.Relation_Definitions.1,Set+1)}
But its not always that easy to guess the definitions introducing a
particular universe index and even harder to guess which definition or
lemma enforces a given constraint.
Best,
Christian
On 05/09/18 20:42, Gaëtan Gilbert wrote:
1) yes
2) and 3)
if you enable printing of universes (Set Printing Universes. in
coqtop/proof general/etc, some GUI toggle in coqide) universe
inconsistencies should print that information
Gaëtan Gilbert
On 05/09/2018 17:57, Christian Doczkal wrote:
Hello everyone,
We have a large development where we have generic structures and some
concrete instances for them. One of these is for relations (X -> Y ->
Prop) with (X,Y : Set).
Now I was trying to generalize this to all instances with (X,Y : Type).
This leads to a universe inconsistency thousands of lines down the road.
I would hope that this is merely a problem of making certain things
universe polymorphic, but I don't manage to come up with a minimal
example reproducing the problem.
At first, I only got the rather uninformative "Universe Inconsistency"
error when trying to load two separately compiled parts of the library.
With some trial and error I got to the point where I have statement that
type checks before the generalized instances are imported and fails to
type check afterwards. This gives me an Error of the form:
"... cannot ensure that "Type@{foo.2}" is a subtype of Type@{bar.3}"
I can use "Print Universes" before and after the Import, but that yields
thousands of constraints and even the diff is not too enlightening.
If I understand the universe mechanism and the error message correctly,
this actually means that assuming "foo.2 <= bar.3" is inconsistent with
the current collection of universe constraints. So here are some
questions:
1) Is my understanding correct?
2) If yes, is there a way to obtain a minimal (or at least sufficiently
small) subset of the current collection of constraints, proving that
"foo.2 <= bar.3" cannot be consistently added.
3) What other things can I do to shed some light onto what is happening?
Any help would be appreciated.
Best,
Christian
