coq-club - Re: [Coq-Club] Dependent match on two vectors
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Dependent match on two vectors
  • Date: Wed, 10 Oct 2018 16:05:02 +0200
  • Organization: LORIA
Le 10/10/2018 à 15:37, Vincent Siles a écrit :
> Inductive vec (A: Type) : nat -> Type :=
> | vnil : vec A 0
> | vcons : forall n, A -> vec A n -> vec A (1 + n)
> Arguments vnil [A].
> Arguments vcons [A] n hd tl.
> Fixpoint vprod (n: nat) (v1 v2: vec nat n) : nat :=
> match v1 in vec _ n0, v2 in vec _ n0 return nat with
> | vnil, vnil => 0
> | vnil, vcons _ _ _ => False_rect nat _ (* 1 *)
> | vcons _ _ _, vnil => False_rect nat _ (* 1 *)
> | vcons _ hd1 tl1, vcons _ hd2 tl2 => (hd1 * hd2) + vprod _ tl1 tl2
> (* 2 *)
> end
The problem is that n is a *shared* dependent parameter in both
v1 and v2. When you proceed by pattern matching on v2 (after v1),
the n parameter is not free of constraints ... Let me suggest
the following solution:
Fixpoint vprod_rec (n : nat) m (v1 : vec nat n) (v2: vec nat m) : n = m
-> nat .
Proof.
refine (match v1 in vec _ n0, v2 in vec _ m0 return n0 = m0 -> nat with
| vnil, vnil => fun _ => 0
| vnil, vcons _ _ _ => fun H => _
| vcons _ _ _, vnil => fun H => _
| vcons _ hd1 tl1, vcons _ hd2 tl2 => fun H => (hd1 * hd2) +
vprod_rec _ _ tl1 tl2 _
end).
+ exfalso; discriminate.
+ inversion H; trivial.
Defined.
Definition vprod n v1 v2 := vprod_rec n _ v1 v2 eq_refl.
