- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] QuickChick installation issues
- Date: Wed, 17 Oct 2018 12:31:31 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=yishuai AT cis.upenn.edu; spf=Pass smtp.mailfrom=yishuai AT seas.upenn.edu; spf=None smtp.helo=postmaster AT mail-io1-f49.google.com
- Ironport-phdr: 9a23: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
Hi Klaus,
Could you try the QuickChick command after `QuickChickDebug Debug On.` and provide the logs?
Also, you're welcome to open QuickChick-specific issues on GitHub.
Yishuai
Klaus Ostermann <klaus.ostermann AT uni-tuebingen.de> 于2018年10月16日周二 下午3:52写道:
I want to use QuickChick with CoqIDE, but I can't get it to work properly.
I installed CoqIDE and QuickChick according to the official instructions.
QuickChick works fine when I run it inside coqtop.
For CoqIDE, I get the following strange behavior:
1. If I run CoqIDE from the command line, QuickChick works but the
output of QuickChick
is displayed in the console from which I started CoqIDE, not within CoqIDE.
2. If I run CoqIDE directly from the Applications bar (not via terminal
window),
I get an error "Could not compile mli file" when I execute a QuickChick
command.
I use Coq 8.8.2 with opam 2.0.0 on a Mac with OS version 10.13.2.
Any ideas?
Klaus
- [Coq-Club] QuickChick installation issues, Klaus Ostermann, 10/16/2018
- Re: [Coq-Club] QuickChick installation issues, Yishuai Li, 10/17/2018
