- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Debugging Universe Inconsistencies
- Date: Wed, 17 Oct 2018 22:20:55 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay12.mail.gandi.net
- Ironport-phdr: 9a23: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
It may not be as pretty but you can do "Fail Fail Constraint U <= V." for the first and "Fail Constraint V <= U." for the second.
Gaëtan Gilbert
On 17/10/2018 22:15, Christian Doczkal wrote:
If someone is touching the naming of universes it would be nice if the automatically
generated names were actually Coq-identifiers. This would allow using them with the
"Constraint" command.
In the same vein, it would be nice if there were also commands like "Consistent Constraint U <= V" that checks
whether "U <= V" is consistent but does not add it and "Implied Constraint U < V" that checks whether
"U < V" is implied by the current universe constraint.
Best,
Christian
On 10/17/2018 06:18 PM, Gaëtan Gilbert wrote:
Also, do you think it would make sense to name the universes of the most
important template polymorphic inductive types (e.g., eq, list, etc.).
That is, replace the definition of eq with:
In https://github.com/coq/coq/issues/2829#issuecomment-350265818 I talk about
a branch of mine which tries to do this automatically, such that for instance
the universe on eq is called eq.0
In it I mention some issues but the universe naming system has changed some
since so maybe it can be made to work reliably (also those issues were not
that bad in the first place).
I'll look into updating it and getting it into Coq.
Gaëtan Gilbert
On 17/10/2018 17:41, Christian Doczkal wrote:
Hi Matthieu,
Thank you very much for your explanation, this seems to be pretty much
exactly what is happening. I don't yet know whether that will allow me
to achieve what I was trying to do last month, but at least I now have
small example exhibiting exactly the behavior you describe.
Naturally, this leads to the question whether there are other
circumstances where the universe constraints inferred for a particular
definition are stronger than what could be inferred or can be inferred
for a convertible definition (or a slight variation).
Universe eq.
Inductive eq (A : Type@{eq}) (x : A) : A -> Prop := eq_refl : eq A x x.
If I understand the mechanisms correctly, this by itself should not
introduce any compatibility issues and might help understand the output
of "Print Universes".
Similarly, reusing this universe for basic lemmas might be a way to
avoid introducing unnecessary universes without introducing too many
compatibility issues, but I'm less sure about that.
Best,
Christian
On 17/10/18 12:00, Matthieu Sozeau wrote:
Hi Christian,
this is a bit surprising but I don't think it is a bug. I guess what
happens is that your use
of @eq partially applied in foo, results in a cumulativity test of the form
Type@{Coq.Init.Logic.8} -> ? <= Type@{U} -> ?
Which by default forces U = Coq.Init.Logic.8. If you enforce your
constraint, it might force
that assignment U = Coq.Init.Logic.8 to fail, and in that case the Coq
typechecker will backtrack
and eta-expand @eq to (fun A : U => @eq A) and only enforce U <=
Coq.Init.Logic.8. You can
confirm this by looking at the definition of foo in the first case, it
should have this eta expansion.
The conclusion is that you should avoid partial applications of
"template" polymorphic constants
like eq, that's one of the quirks of the feature.
Best regards,
-- Matthieu
On Tue, Sep 11, 2018 at 4:04 PM Christian Doczkal
<christian.doczkal AT ens-lyon.fr
<mailto:christian.doczkal AT ens-lyon.fr>>
wrote:
Hello,
I stumbled across another universe behavior where I am not sure whether
this is a bug or not.
I have declared a bunch of Universes, say L,S,M and U and used them in a
bunch of definitions. This ensures that U,S <= L as can be witnessed by:
Fail Constraint L < S.
Fail Constraint L < U.
Now I can enforce S = L before some definition:
Constraint S = L.
Definition foo := Foo Type@{U} ... (@eq)
Constraint S = L.
In this case, everything typechecks. However, if I remove the first
line, then the universe constraints imposed by foo change (become
stronger) and the third line yields a universe inconsisteny.
In the first case, the constraints imposed by foo are:
U < M and U <= Coq.Init.Logic.8 (the argument of eq)
Without the constraint "S = L", I get
U < M and U = Coq.Init.Logic.8
So S = L is consistent with foo, but ruled out by it unless enforced
before.
The concrete example is again too large, but having discovered the
"Constraint" command, coming up with a reasonably sized example may be
feasible.
Best,
Christian
PS. It would be nice if the automatically generated universe names were
actually names in the Coq sense, so that one could use them with the
Constraint command.
On 10/09/18 14:53, Matthieu Sozeau wrote:
> Dear Christian,
> There is documentation in dev/doc/universes about the changes
necessary.
> The main idea is that if your tactic produces a term with polymorphic
> constants in it, it must produce one fresh instance of the constant at
> each use. Before giving the final proof term containing those fresh
> instances, you can call a type inference function to gather the
universe
> constraints necessary for the whole term to typecheck automatically.
> Maybe a look at the OCaml code you use could help us fix this.
> The « cannot ensure that i <= j » error could also be because that
> constraint is not present in the graph you produce in a tactic I
believe.
> The order-of-Imports issue is a bug for sure. Note that if you have a
> module A with everything polymorphic then importing it incurs no
global
> constraints so the bug couldn’t happen in that case.
> Best,
> — Matthieu
> Le lun. 10 sept. 2018 à 14:28, Christian Doczkal
<mailto:christian.doczkal AT ens-lyon.fr>>>
a
> écrit :
> Hi,
> >> - Require Import A B. succeeds
> >> - Require Import B A. fails
> > That sounds like a bug, you can open an issue on github with
> > reproduction instructions and we will look into it.
> Unfortunately, that's an internal repository with well over
10K lines,
> and the problem occurs at the end. Should I manage to find a small
> example, I will open an issue.
> >> globalization of polymorphic reference <ID> would forget
universes.
> > Unfortunately various tactics and commands do not support or
badly
> > support universe polymorphism. This error means some
function hasn't
> > been adapted. It should probably be an anomaly.
> > Depending on what exactly is failing it may be possible for
us to fix
> > it, or it could be beyond our current manpower.
> This happens when calling one of our own tactics written in
OCaml. So
> how does one have to adapt tactics in order to properly
support universe
> polymorphism? (The error occurred while trying to see what
happens if I
> make just about everything universe polymorphic, so it may or
may not be
> necessary to fix this)
> Thanks for the pointers,
> Christian
- Re: [Coq-Club] Debugging Universe Inconsistencies, Matthieu Sozeau, 10/17/2018
- Re: [Coq-Club] Debugging Universe Inconsistencies, Christian Doczkal, 10/17/2018
- Re: [Coq-Club] Debugging Universe Inconsistencies, Gaëtan Gilbert, 10/17/2018
