coq-club - [Coq-Club] Coq 8.9+beta1 is out!
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Coq 8.9+beta1 is out!
  • Date: Tue, 6 Nov 2018 10:46:14 +0100
Dear Coq users,
The Coq development team is pleased to announce the release of the
first beta version of Coq 8.9, available at
https://github.com/coq/coq/releases/tag/V8.9%2Bbeta1
Source, Windows and OS X packages are available.
The main changes are as follows.
Kernel: mutually recursive records are now supported.
Notations:
- Support for autonomous grammars of terms called "custom entries".
- Deprecated notations of the standard library will be removed in the next version of Coq, see the CHANGES.md file for a script to ease porting.
- Added the Numeral Notation command for registering decimal numeral notations for custom types.
Tactics: introduction tactics intro/intros on a goal that is an existential variable now force a refinement of the goal into a dependent product rather than failing.
Decision procedures: deprecation of tactic romega in favor of lia and removal of fourier, replaced by lra which subsumes it.
Proof language: focusing bracket "{" now supports named goals, e.g. "[x]:{" will focus on a goal (existential variable) named x.
SSReflect: the implementation of delayed clear was simplified: the variables are always renamed using inaccessible names when the clear switch is processed and finally cleared at the end of the intro pattern. In addition to that, the use-and-discard flag "{}" typical of rewrite rules can now be also applied to views, e.g. "=> {}/v" applies v and then clears v.
Vernacular:
- Experimental support for attributes on commands as in "#[local] Lemma foo : bar." Tactics and tactic notations now support the deprecated attribute.
- Removed deprecated commands Arguments Scope and Implicit Arguments in favor of Arguments.
- New flag Uniform Inductive Parameters to avoid repeating uniform parameters in constructor declarations.
- New commands Hint Variables and Hint Constants for controlling the opacity status of variables and constants in hint databases. It is recommended to always use these commands after creating a hint databse with Create HintDb.
- Multiple sections with the same name are now allowed.
Library: additions and changes in the VectorDef, Ascii, and String libraries. Syntax notations are now available only when using Import of libraries and not merely Require (source of incompatibility, see CHANGES.md for details).
Toplevels: coqtop and coqide can now display diffs between proof steps in color, using the Diffs option.
Documentation: we integrated a large number of fixes to the new Sphinx documentation.
Tools: removed the gallina utility and the homebrewed Emacs mode.
Packaging: as in Coq 8.8.2, the Windows installer now includes many more external packages that can be individually selected for installation.
Version 8.9 also comes with a bunch of smaller-scale changes and
improvements regarding the different components of the system. Most
important ones are documented in the CHANGES.md file.
