- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to evaluate reflexive tactics? (in a robust way)
- Date: Thu, 8 Nov 2018 13:43:07 +0100
Le 08/11/2018 à 11:56, Armaël Guéneau a écrit :
A good idea is generally not to store the constants directly as an
argument of the constructor. It is better to store them in a map and use
an index in the constructor. There are two advantages. First, you no
longer care about it being evaluated. Second, your simplification code
can now be made aware that two constants are equal.
Thanks, that sounds like a better idea indeed. Could you detail a bit
more how it would work, though? The interpretation function would still
have to take this map as argument, if I'm not mistaking? How do you
prevent the map itself (and the constants inside) from being evaluated?
You abstract the map away, at the time you force the reduction. Your goal should look as follows after applying your main correctness theorem:
|- eval (simplify reified_term) constants
You can turn it into two goals, e.g. by rewriting:
|- simplify reified_term = ?1
|- eval ?1 constants
Then you force the reduction in the first goal. Notice that it does not mention "constants" anywhere, so you are fine.
Best regards,
Guillaume
- [Coq-Club] How to evaluate reflexive tactics? (in a robust way), Armaël Guéneau, 11/08/2018
- Re: [Coq-Club] How to evaluate reflexive tactics? (in a robust way), Guillaume Melquiond, 11/08/2018
- Re: [Coq-Club] How to evaluate reflexive tactics? (in a robust way), Armaël Guéneau, 11/08/2018
- Re: [Coq-Club] How to evaluate reflexive tactics? (in a robust way), Gabriel Scherer, 11/08/2018
- Re: [Coq-Club] How to evaluate reflexive tactics? (in a robust way), Sylvain Boulmé, 11/08/2018
