- From: Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>
- To: Li-yao Xia <lysxia AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Make constants/functions opaque for [rewrite]
- Date: Sun, 18 Nov 2018 22:37:09 +0000
- Accept-language: en-CA, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=fdhzs2010 AT hotmail.com; spf=Pass smtp.mailfrom=fdhzs2010 AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM05-DM3-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
I suppose this is a bug. If you try
rewrite (tam'_S x).
then the RHS is rewritten. The refman doesn't mention rewrite will try to be this smart either.
However, this only looks feasible when you have two definitionally equal functions. Is it the case in your actual use case?
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Li-yao Xia <lysxia AT gmail.com>
Sent: November 18, 2018 5:18 PM
To: coq-club AT inria.fr
That's quite a surprising behavior of rewrite. One way to get what you
want is to abstract one of them with the remember tactic before rewriting.
remember tam as tam0. rewrite tam'_S. subst tam0.
Li-yao
On 11/18/18 3:17 PM, Maximilian Wuttke wrote:
> Hi Coq Club members,
> In my project I have some functions on natural numbers. Two of them are
> coincidently equal, although the contexts in which I use them are not
> related to each other. I also have shown lemmas about these functions.
> (Yes, these lemmas are duplicated for the duplicated functions.)
> What can I do, so that [rewrite] _does_ distinguish between these
> functions, i.e. [rewrite] sees the names of the two functions as
> distinct constants? Below is a minimal example.
> The reasons for wanting this are two-fold:
> 1. It can confuse the user of my library. ("Why is there suddenly a
> totally unrelated function after [autorewrite]?" ~> this may break
> proofs with [omega])
> 2. It is more efficient to not unfold the constants.
> I already tried out some things that I found while reading the refman,
> but mabye I missed something.
> In case it matters:
> $ coqtop --version
> The Coq Proof Assistant, version 8.8.2 (November 2018)
> compiled on Nov 18 2018 20:32:22 with OCaml 4.07.1
> Sincerely
> Maximilian Wuttke
> (* I have two totally unrelated function, that just happen to be
> coincidently equal. (They actually occur at different parts of the
> project) *)
> Definition tam (x : nat) := S x.
> Definition tam'(x : nat) := S x.
> (* Both functions are compatible w.r.t. some function, e.g. [S] *)
> Lemma tam_S (x : nat) : tam (S x) = S (tam x).
> Proof. reflexivity. Qed.
> Lemma tam'_S (x : nat) : tam' (S x) = S (tam' x).
> (* Now I want that [rewrite] sees them as distinct constants. *)
> (* But nothing of this solves my problem *)
> Arguments tam : simpl never. Arguments tam' : simpl never.
> Hint Opaque tam tam'.
> Typeclasses Opaque tam tam'.
> Opaque tam tam'.
> (* I also expect this to not simplify. This works, thanks to the above
> [Arguments] vernacular: *)
> Eval cbn in tam 42.
> (* I DO NOT want to be able to proof this with [rewrite] *)
> Goal forall x, tam (S x) = tam' (S x).
> Proof.
> intros.
> (* This should change the goal to [tam (S x) = S (tam' x)] *)
> rewrite tam'_S.
> (* It reduces to [S (tam' x) = tam' (S x)] instead. I.e. it saw that
> [tam=tam'] and rewrote [tam'_S] in [tam (S n)]. This is exactly what I
> want to prevent. *)
> Abort.
> (* At a later part of the project, I want to be able to unfold the
> constants though. So making them completly opaque (i.e. with [Qed]) is
> no option. *)
> Goal forall (x : nat), tam x <= tam (x+x). (* (actually we want to show
> that a function using [tam] is in some complexity class) *)
> Proof.
> Require Import Omega.
> Transparent tam.
> intros. unfold tam. omega.
> Qed.
Li-yao
> In case it matters:
> $ coqtop --version
> Sincerely
> Maximilian Wuttke
> project) *)
> Opaque tam tam'.
> Eval cbn in tam 42.
> Proof.
> intros.
> rewrite tam'_S.
> want to prevent. *)
> Abort.
> no option. *)
> Proof.
> Transparent tam.
> Qed.
- [Coq-Club] Make constants/functions opaque for [rewrite], Maximilian Wuttke, 11/18/2018
- Re: [Coq-Club] Make constants/functions opaque for [rewrite], Li-yao Xia, 11/18/2018
- Re: [Coq-Club] Make constants/functions opaque for [rewrite], Jason -Zhong Sheng- Hu, 11/18/2018
