coq-club - Re: [Coq-Club] Latest Coq does not install smoothly using opam on ubuntu 16.04
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Latest Coq does not install smoothly using opam on ubuntu 16.04
  • Date: Mon, 26 Nov 2018 14:09:49 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr1-f66.google.com
  • Autocrypt: addr=theo.zimmi AT gmail.com; prefer-encrypt=mutual; keydata= xsFNBFP+V00BEADi9eGxuXfvs0HxaYDxrOBpCJWakA4+lCi3KUGqNS5Xq0V7q+BWZZmF/pOO x4EemIickFV+DA/Yp9542XWw1vMK3uGAUpnB4sUvD+qPDnRFHDZH60p1b8rRzukHRdukW33g QsEjDdNp9iVebuBMe+IU2gdpdZxjgxzxShQMIHOX1Az65oC81eEV37XJ7b89WjArEEe0Hxcg 9+jFH3P3pNdlVaxMgEaYxeepTEfBIhWJjobr299gkgUm2a79vYnci0VONNk3crZqpNvrDK9h bqBgsEUv7t8JnIDQOJTncuoeZA+YFkceYKysO4tyDgNPgXSuI8tUfo7eU1uacNvX7LoKH1nT d4Gr26nPUyj8ntnvnT88LK+CxrrfYkUxtK5pYIQLzJSnCaCuoxOu4WJn+6PPtMhUNWC50fmA +HBt3v8YhheNEEbBZPqEGE9O1A0xB5oJJ3UCsf2VpxiEc3qCTzZHPbw5hYsS96MRysJ3gl9Z OG/u8M5r/JlyiDbVOj6WEcjgMYhuowbEX45UCCufgMWlVFDqKj685zCwhPxYSKvW2+Pkvw1K YmM4tQuF3bH2oQXe8W791N39JXQU/LHD7EHnmoJW/6ySc7Mv2f9cId/HY/DeM1U1TTTEEr1Q j6o/6PdRHGWT5PZpbNDy9+sdBieF1JWuXx24KHbhbN/OCebiewARAQABzSdUaMOpbyBaaW1t ZXJtYW5uIDx0aGVvLnppbW1pQGdtYWlsLmNvbT7CwX0EEwEIACcFAli5dBUCGyMFCQlmAYAF CwkIBwIGFQgJCgsCBBYCAwECHgECF4AACgkQ8XRKCUL1Nsf97A//QpWey31m7X20iHRRO833 BPyziP9QbIQveB8BofZfjWXBJoGExP2EZdb10UMwU0tsnD6NT5E8nKr9rRRTtnwXOcqaQHGd Y4mVLEyJYwZ8g4uZglMyTCHx6k064Ik4c5DysS/15AB72SZm+fJFayIzSY1syvTnTPxTnNx7 l697IbjS3aq3/W+vQ6MwnDgnQqggGMiA0+Tmp5VPCZX9deLmXWC1zeXe/PdCstPzeHTiIHgD wQW+0edCBELbJdhoVBKsQ3OfBK7uMJBXug7zqI3wAoywvd/E12tFzZJhLZiq8arDIimeccf4 bFZUIy17ApiFfAZJU5Rm71H29IFFMTyQxi4QFFiPjWKwtUTDB/Xv6V8nGgdhOHkNgjnRpPn4 jNxSnvr3/f1OW2yGFYyxTUlmYg72eTkSNlPAwd+WA5K3aQQtwUERzhPsK2l4Smjqr7NcI+5X 0aHBVRyRGrTmtTRz/hdyoGoxx4ts1TacquKHx88YH9GZhEng9h+Ak70oQYD9u+atp93wTyTo tghwB5Ewm3O9oruIdQtWx2H4PtP4Y3V1O/DjK42D3wKwikiHisCTKtbuIsgLTnxebWC7wN0q X9nln3KJkEnxZ/6pjLQ3XZB5YeUq58bBnr06VTZYjjYM5aZ6cQrOrnWXvrsrTh367cPKesk5 G5h/itHB0UQc+eXOwU0EU/5XTQEQAL7skL+t5KvE/j2zAzuUFtwjIA+GPBcwOJnITdT3fddN S18gCBx+EH/YPbCphKXOxRFeaD+EDuC1Ls5XK+lYu9hR7rurW7RQI+1XKO7KHQvp4i2I8J4C C+kmMw9K7fysHFG9ckiw1G5WrwiiPZHLadRIAfXwMLoDfRRNu/W8ogjm1m+UWm88DISrkIbE BYEw/fWX8QGGcFvExrFAgXyXXn4vVG90XNre+wJwIADcCqQJXCfzNF/tyetcGEwc3BZiUe/Q Ha/3xLDSm19rDkVWSpWGUr0uSziPSR9kYw6q4F1gKdvex6hnduRMEJLwFRfiHKnHZO2uN8Zj MsB1EklGvkockjkThQfFjeU3zysxfsl4tQRROpglgs1MhiMZpvCdnNTn+Gr+YHQ0sueBxpk0 6GHMmE4C4jcrLFXwfEWOnk6ISHluZS1f9qRnNZzj9ICJItT7cn1KE54jZjmVudi4kOSbihaZ 70PrXMhwphz4nVxSRMIsXdNwSkpCrcOatDS4E7EjRgHW5+CP5WON2aJPD8htAtKNej5nPbTD NFJKz6nG4jdDpxtY0PEkMHarrBpWaIdPEPgdCew5Ns5cAZC0vMkJU8uuSoEumGqzUwdVIWaV p0iZ7MTaWSZeifx7Y6x5YkYR5dMGGzKW5GeLQ7emG0I1BTcFeP+VAGewLA5xWjnhABEBAAHC wWUEGAECAA8FAlP+V00CGwwFCQlmAYAACgkQ8XRKCUL1NscXDRAAx5Y5fyDX/HvFD2Sp4E1h HbtNsPfDQ076U3qvg31e7d5560fW5hwSgZ3++3kGRO7QFTq3edo3oEEWiHuHBJxT7eXSPhXY vsM/atDyQ7Zy6fEUVuv77b3TEDHuWvn4A2kBI+ApCzXohscTuCc/PvVCoDrRQ++be2hIlxsq M7DnRr3/6FI8chCUHj3bXeXtPp8M74/3RGCiwvPZ7825NU0JP6jj1yeEuy6ts/GaZFsDj3sz TxCeZxbdARFxqmT0lf3yF2uQWj35jwqBUC/S+07fZfRRRFXwHTSSzsTTg4JKvsEpq6v0/ryc ETXqwstze+nvPvZ/bLlkiFulLFajYdIky+t5JmjmMEW0/NpK4nRo/QNuTyF1vG1/tjg/q5CZ gW++ZBoYuOR/+roFRPEKIu6Aa843e+QXvpHv4WHN1viH7ufY3D389hKkkhtnEvUu1Mv7ITDD ryw3ok6KFBrjvMQVOp0L7yZc9RYtJ0mXH9n1wWJL94q4hbUJ7fqz2rv8RbTGQoqKfDQVuVuo gH36yLP9s+RKxePuqaTn6DOOHF0/hhMCwes9pWs6ObrEPUVG1YtM6TwopIUJtuLZFWWb3X1Q 4W8EyZElzlCZhLTVhJT7p2k8xBEjpdMpsHhBMjOMljCUeRdJX55g2DVAwx3fvhdOJkuXY5Tl nCgw1L3/lCt46SU=
  • Ironport-phdr: 9a23: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
  • Openpgp: preference=signencrypt
Hello,
I recently discovered the existence of the following ppa which includes
an opam 2 package for both bionic and cosmic:
https://launchpad.net/~avsm/+archive/ubuntu/ppa
Might be of interest to some.
Disclaimer: I haven't tested it (as I don't use Ubuntu, nor opam for the
matter).
Théo
On 14/11/2018 00:23, Christian Doczkal wrote:
> Hello Arthur,
>> - The opam package for coqIDE associated with coq=8.8.2 is only
>> distributed in opam2 format
> Good point, I only pushed for the coq package to be in the coq-released
> repository (which is still in 1.x format). I suppose there is no reason not
> to add the coqide package as well.
>> - opam2 activates sandboxing by default, using bubblewrap >= 2.0 (program
>> name bwrap)
>> - ubuntu 16.04 distributes only an older version of bubblewrap
> As far as I know, not even Ubuntu 18.10 ships opam-2. I would already
> consider manually installing opam as "not smooth" (as in, it leads to
> programs being installed that no package manager knows about).
>> - opam2 installation scripts fails with an obscur error when using the old
>> bubblewrap.
> I'm not surprised...
> Best,
> Christian
Attachment: signature.asc
Description: OpenPGP digital signature
