- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proof in functional style
- Date: Thu, 29 Nov 2018 21:14:02 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=llee454 AT gmail.com; spf=Pass smtp.mailfrom=llee454 AT gmail.com; spf=None smtp.helo=postmaster AT mail-pg1-f176.google.com
- Ironport-phdr: 9a23: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
Hi mukesh,
I hope this helps you identify the problem in your proof.
- Larry
Require Import List.
Import ListNotations.
Open Scope list_scope.
Fixpoint intersperse (A : Type) (c : A) (l : list A) : list A :=
match l with
| [h] => [h]
| h :: t => h :: c :: intersperse _ c t
end.
Lemma map_intersperse_not_working : forall (A B : Type) (f : A -> B) (c : A) (l : list A),
map f (intersperse _ c l) = intersperse _ (f c) (map f l).
Proof.
exact (
fun (A B : Type) (f : A -> B) (c : A)
=> list_ind
(fun l => map f (intersperse _ c l) = intersperse _ (f c) (map f l))
(eq_refl [])
(fun x0
=> list_ind
(fun xs => map f (intersperse _ c xs) = intersperse _ (f c) (map f xs) -> map f (intersperse _ c (x0 :: xs)) = intersperse _ (f c) (map f (x0 :: xs)))
goal:
map f (intersperse _ c (x0 :: [])) = intersperse _ (f c) (map f (x0 :: []))
map f [x0] = intersperse _ (f c) [f x0]
[f x0] = [f x0]
(fun _ => eq_refl [f x0])
goal:
map f (intersperse _ c (x0 :: y0 :: ys)) = intersperse _ (f c) (map f (x0 :: y0 :: ys))
map f (x0 :: c :: intersperse _ c (y0 :: ys)) = intersperse _ (f c) (f x0 :: f y0 :: (map f ys))
(f x0 :: f c :: map f (intersperse _ c (y0 :: ys)) = (f x0 :: f c :: intersperse _ (f c) (f y0 :: map f xs))
(fun y0 ys _ (H : map f (intersperse _ c (y0 :: ys)) = intersperse _ (f c) (map f (y0 :: ys)))
=> ((eq_ind
(map f (intersperse _ c (y0 :: ys)))
(fun zs => (f x0 :: f c :: map f (intersperse _ c (y0 :: ys))) = (f x0 :: f c :: zs))
(eq_refl (f x0 :: f c :: map f (intersperse _ c (y0 :: ys))))
(intersperse _ (f c) (map f (y0 :: ys)))
H))))).
On Fri, 2018-11-30 at 15:24 +1100, mukesh tiwari wrote:
Hi Everyone, I have written a function (basically Haskell intersperse function)Fixpoint intersperse (A : Type) (c : A) (l : list A) : list A :=
match l with
| [h] => [h]
end.
Compute (intersperse _ 0 []).
Compute (intersperse _ 0 [1]).
Compute (intersperse _ 0 [1; 2; 3]).and proof about it's correctnessLemma map_intersperse : forall (A B : Type) (f : A -> B) (c : A) (l : list A),
Proof.
intros A B f c.
induction l.
+ cbn; auto.
+ destruct l.
++ cbn; auto.
++ cbn in *. repeat f_equal.
(* At this point, the induction hypothesis is [1], and assumption is able to discharge
the proof *)
assumption.
Qed.
Now I rewrote the same proof in function style using refine tactic.
refine (fun A B f c =>
fix F l :=
match l as l'
return l = l' ->
map f (intersperse A c l') =
intersperse B (f c) (map f l') with
| [] => fun H => eq_refl
| [h] => fun H => eq_refl
| h1 :: h2 :: t => fun H => _
end eq_refl).
pose proof (F (h2 :: t)).
cbn in *. repeat f_equal. Guarded.
(* At this point assumption H0 is same as goal [2] so apply H0 should discharge the goal*)apply H0. Guarded.(* I am getting Recursive definition of F is ill-formed. *)Could some one point me why it's saying F is ill-formed ? I am calling it smaller argument (At least that is my understanding).I got working solution with help of Li-yao [3], but I am wondering why destruct t is making a difference in this solution which I am doing explicitly in previous one (matching on one element list [h])
fix F l :=
match l as l'
return l = l' ->
| h :: t => fun H => _
end eq_refl).
pose proof (F t).
destruct t.
+ cbn. exact eq_refl.
+ cbn in *. repeat f_equal. apply H0. Guarded.
Qed.Best regards,Mukesh Tiwari
- [Coq-Club] Proof in functional style, mukesh tiwari, 11/30/2018
- Re: [Coq-Club] Proof in functional style, mukesh tiwari, 11/30/2018
- Re: [Coq-Club] Proof in functional style, Larry Lee, 11/30/2018
- Re: [Coq-Club] Proof in functional style, Pierre Courtieu, 11/30/2018
