- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] What is a successor universe?
- Date: Thu, 17 Jan 2019 20:50:40 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay5-d.mail.gandi.net
- Ironport-phdr: 9a23:h4PlThxcp9BHEc/XCy+O+j09IxM/srCxBDY+r6Qd1OIUIJqq85mqBkHD//Il1AaPAd2Lraocw8Pt8InYEVQa5piAtH1QOLdtbDQizfssogo7HcSeAlf6JvO5JwYzHcBFSUM3tyrjaRsdF8nxfUDdrWOv5jAOBBr/KRB1JuPoEYLOksi7ze+/94HQbglSmDaxfa55IQmrownWqsQYm5ZpJLwryhvOrHtIeuBWyn1tKFmOgRvy5dq+8YB6/ShItP0v68BPUaPhf6QlVrNYFygpM3o05MLwqxbOSxaE62YGXWUXlhpIBBXF7A3/U5zsvCb2qvZx1S+HNsDwULs6Wymt771zRRH1likHOT43/mLZhMN+g61Uog6uqRNkzo7IY4yYLuZycr/TcN4YQ2dKQ8ZfVzZGAoO5d4YBDvAOOvpEr4bnoVsBtRqwBQioBOz01DBInGP21rA93uQuCw7JwhAgEMgIsHjOo9X1NaMSXvurw6nS0TXOdOhW2TT96YjTcRAhoPSMXbdufsrL00UvER3KjkmJpIHjIjib1fwNvnCF4+Z9V++jkWwqpx1rrjSyxcohhJPFip8Rx13G7Sl13ps5KNOiREJmYdOoDoFcuzybOodoWM8vR2VltSAnwbMco5G7ZjIFyJE/yh7fdfOHd4+I7wr5VOmPJTd3nnJkdbKmixmv60Sgz/fzVsiw0FpQoSpKiN/MuW0M1xDJ7MiIVOd98l+g2TaJyQ/T9vlJLV4pmafZMZIswKI8moAOvUnAECL6glj6gauUe0k8/+in8eXnYrHopp+GMI90jxnzMqs0lcOhHeQ3KA4OU3KU+eS90L3s5lP2QK9WjvAtianZs5DbJd8Ypq64Bg9V15gs6wylAzegztsYgWELLEhZdxKfk4jpJ1bOLejkAve4mlSgiStkx/TbPrL6GZjNNXjCkLL5fbln8UJcyQwzzcpe551OEL0BLujzCQfNs4nTCQZ8OAipyc7mDs9838UQQzGhGKicZYzbMkOB4NUAIu2GaZUJ8GLyIvU57viogn49k1IHYYGy3ooMa3G9G/l8ZUOUfSy/0Z86DW4Ws19mH6TRg1qYXGsLPifgb+cH/jg+TbmeI8LGT4GpjqaG2X7lTIZVd3tFC1WJHG2ucYiYCa5VNHCiZ/R5mzlBboCPDpc73Ejw5hT52qFkL+/R9zdes5//hoAsur/j0Coq/DkxNPyzlmGAS2YuwzESSjs/zf06rQp4w1aHl6dxhfBZU9pe+6ERXw==
Because then you would get constraints max(u,v) <= max(x,y) which can't be encoded as constraints between variables in our universe graph.
Gaëtan Gilbert
On 17/01/2019 20:36, Arthur Azevedo de Amorim wrote:
Yes, if algebraic universes are not allowed in definitions, it makes sense that these upper bounds need to be explicitly declared. Why isn't it possible for definitions to include algebraic universes?
Em qui, 17 de jan de 2019 às 12:04, Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net <mailto:gaetan.gilbert AT skyskimmer.net>> escreveu:
> If I omit the annotation, Coq complains that I haven't declared the
> universe where the definition should live:
This is because it needs to live in some upper bound universe, as i+1
isn't allowed. ie
Polymorphic Definition pack2@{i j|i < j} (T : Type@{i}) (x : T) :
pack@{j} :=
Pack pack@{i} (Pack@{i} T x).
Gaëtan Gilbert
On 17/01/2019 15:18, Arthur Azevedo de Amorim wrote:
> Coq accepts the following snippet, which declares a
universe-polymorphic
> type that lives in a successor universe:
> Polymorphic Inductive pack@{i} : Type@{i+1} :=
> Pack { sort : Type@{i}; elt : sort }.
> However, if I try to take the successor of a universe level
elsewhere, I
> get a parse error:
> Polymorphic Definition pack2@{i} (T : Type@{i}) (x : T) :
pack@{i+1} :=
> (* Toplevel input, characters 65-66: *)
> (* > Polymorphic Definition pack2@{i} (T : Type@{i}) (x : T) :
> pack@{i+1} := Pack pack@{i} (Pack@{i} T x). *)
> (* Error: Syntax error: [constr:universe_level] or '}' expected (in
> [instance]). *)
> Polymorphic Definition pack2@{i} (T : Type@{i}) (x : T) :=
> (* Toplevel input, characters 61-65: *)
> (* > Polymorphic Definition pack2@{i} (T : Type@{i}) (x : T) := Pack
> (* Error: Universe {Top.72} is unbound. *)
> Is there any way of convincing Coq that pack2's codomain is
pack@{i+1}?
> Thanks!
> Best,
> Arthur
- [Coq-Club] What is a successor universe?, Arthur Azevedo de Amorim, 01/17/2019
- Re: [Coq-Club] What is a successor universe?, Gaëtan Gilbert, 01/17/2019
- Re: [Coq-Club] What is a successor universe?, Arthur Azevedo de Amorim, 01/17/2019
