- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] "Sequence is associative." (?)
- Date: Wed, 23 Jan 2019 12:23:38 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi Theo,
What does
split; [> foo1; foo2 ..].
mean?
I find in the documentation that
tac1 ; tac2 means apply tac2 to every subgoal resulting from tac1,
and that
[> tac1 | tac2 | ...] means apply tac1, tac2, etc, one to each of
several subgoals.
Is [> foo1; foo2 ..] simply a tactic itself, or is
split; [> foo1; foo2 ..] a compound expression with a special meaning?
(If so, I couldn't find it in the documentation)
Anyhow, the question raised by Qinxiang which also puzzles me is
illustrated in more detail by the following
Variable a: nat.
Variable b: nat.
Ltac foo1 := try reflexivity; try split.
Ltac foo2 := try reflexivity.
Ltac foo3 := foo1 ; foo2.
Goal exists x, (x = a /\ x = a + b) /\ x = b.
eexists.
split; (foo1; foo2). (* sets x to b, why ?? *)
Undo.
split ; foo3. (* sets x to b, why ?? *)
Undo.
split. 1 : foo3. 2 : foo3. Show. (* sets x to a *)
Undo. Undo. Undo.
split. all : foo3. (* sets x to b *)
Abort.
Ie, here, it would seem that
split ; foo3.
does the same as
split. all : foo3.
which does the same as
split. 2 : foo3. 1 : foo3.
but is different from
ie the step
all : foo3.
acts on subgoal 2 before subgoal 1
whereas in a different example
Goal exists x, (x = a) /\ x = b.
eexists.
(split; foo2). (* sets x to a *)
Undo.
split. all : foo2. (* sets x to a *)
Undo. Undo.
split. 1 : foo2. foo2. (* sets x to a *)
Undo. Undo. Undo.
split. 2 : foo2. foo2. (* sets x to b *)
Abort.
split. all : foo2.
acts on subgoal 1 before subgoal 2
This is what I and probably also Qinxiang don't understand.
So the question is what are the semantics of tac1 ; tac2
and of all : tac?
(Thanks Qinxiang for working out this example to illustrate the issue, I
tried to do so myself but found it highly non-trivial)
Cheers,
Jeremy
On 01/23/2019 10:13 PM, Théo Zimmermann wrote:
> I suppose that you thought that:
> Goal exists c, (c = a /\ c = a + b) /\ c = b.
> eexists.
> Abort.
> would mean something like:
> eexists.
> Abort.
> but that is not the case.
> Le mer. 23 janv. 2019 à 12:02, Théo Zimmermann
> <theo.zimmi AT gmail.com
> <mailto:theo.zimmi AT gmail.com>>
> a écrit :
> Why did you think the output should be different? The part of the
> manual cited by Jeremy precisely says the converse.
> Le mer. 23 janv. 2019 à 11:49, Cao Qinxiang
> <caoqinxiang AT gmail.com
> <mailto:caoqinxiang AT gmail.com>>
> a écrit :
> This is an interesting question. I try the following script.
> Variable a: nat.
> Variable b: nat.
> eexists.
> Abort.
> eexists.
> (split; foo1); foo2.
> Abort.
> I thought the outcome should be different. But it turns out to
> be the same. Anyone can explain that?
> Best,
> Qinxiang Cao
> Shanghai Jiao Tong University, John Hopcroft Center
> Room 1110-2, SJTUSE Building
> 800 Dongchuan Road, Shanghai, China, 200240
> On Wed, Jan 23, 2019 at 6:19 PM Théo Zimmermann
> wrote:
> Le mer. 23 janv. 2019 à 10:33, Jeremy Dawson
> <Jeremy.Dawson AT anu.edu.au
> <mailto:Jeremy.Dawson AT anu.edu.au>>
> a écrit :
> Hi,
> thanks for all the answers to my previous questions,
> some of which I'm
> still working through.
> In https://coq.inria.fr/refman/proof-engine/ltac.html
> under Semantics then under Sequence it says
> I would take that to mean that
> (tac1 ; tac2) ; tac3
> is the same as
> tac1 ; (tac2 ; tac3)
> But is this so? What if the tactics do some
> instantiating of
> existential variables, then the order of attacking
> subgoals would matter?
> The order would be the same in both cases.
> Also, for the same reason, it would be useful to know, for
> tac1 ; tac2
> which order tac2 is applied to the subgoals resulting
> from tac1
> This can depend on tactic, but in practice it would be in
> the listed order of the goals for virtually all tactics.
> Cheers,
> Jeremy
- [Coq-Club] "Sequence is associative." (?), Jeremy Dawson, 01/23/2019
- Re: [Coq-Club] "Sequence is associative." (?), Théo Zimmermann, 01/23/2019
- Re: [Coq-Club] "Sequence is associative." (?), Cao Qinxiang, 01/23/2019
- Re: [Coq-Club] "Sequence is associative." (?), Jeremy Dawson, 01/23/2019
- Re: [Coq-Club] "Sequence is associative." (?), Jean-Christophe Léchenet, 01/23/2019
- Re: [Coq-Club] "Sequence is associative." (?), Jeremy Dawson, 01/24/2019
- Re: [Coq-Club] "Sequence is associative." (?), Jeremy Dawson, 01/28/2019
- Re: [Coq-Club] "Sequence is associative." (?), Pierre Courtieu, 01/28/2019
