coq-club - Re: [Coq-Club] external editor in coqide
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] external editor in coqide
  • Date: Thu, 24 Jan 2019 12:26:27 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=a AT anderslundstedt.se; spf=Pass smtp.mailfrom=anders AT anderslundstedt.se; spf=None smtp.helo=postmaster AT mail-wm1-f42.google.com
  • Ironport-phdr: 9a23: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
On Thu, Jan 24, 2019 at 11:11 AM Théo Zimmermann
<theo.zimmi AT gmail.com>
wrote:
> I just discovered https://framagit.org/manu/coq-au-vim which apparently
> supports talking with Coq using the asychronous XML protocol (like CoqIDE
> and the corresponding Proof General branch).
> Are some vim people using it? Is it good?
> Of course, there is also the older coquille which also provides vim
> support, in the style of Proof General. I don't know if it kept working
> with recent Coq version though: the last commit is quite old.
I have not been using Coq much the last couple of years, but when I
did I was using Vim exclusively. So for what it is worth, here are
some additional advice.
There is Coqtail which seems to be well maintained and which was what
I used last:
https://github.com/whonore/Coqtail
As for Coquille some of the forks might be more up to date, check:
https://github.com/the-lambda-church/coquille/network
What I did some years ago when looking for a Coq plugin for Vim was to
search "coq vim" on Github. When none of the results seemed to work
out of the box I managed to find something by looking through their
forks. So that might be an option of last resort.
Best,
Anders
